Lost all keys 2014 Prius C
Discussion in 'Prius c Main Forum' started by Roshcats, Jan 12, 2023.
  1. Roshcats
    Roshcats New Member
    Dallas, TX
    2014 Prius c
    I have a 2014 Prius C Four and my employees lost all the keys. I can get a key cut, but how can I get this going without towing to a dealer. Is there a procedure that can be done with no old keys or what has to be done.
  2. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Ouch, a four and all keys lost? that's not going to be easy or cheap, even after towing to a dealer.
    Good luck!
  3. Seadaemon
    Seadaemon Junior Member
    Mission British Columbia Canada
    2015 Prius c
    Technology
    Is a Prius 4 the same as a Prius technology ?
  4. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    I couldn't tell you the trim equivalents between USA & Canada delivery, sorry.
    @Tideland Prius may be able to help.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    There is no "Prius 4".
    The 4 is just a "trim level" or a standard list of options.
    The C, however, is a bit different than a standard Prius in some respects.
    Typically when you loose ALL of the keys, the dealer will tell you that you need:
    2 new key FOBS, one of which the employees should never touch AND the computer security board because it can't be re-programmed without one working key. Seems like I remember the cost for all of that can approach $1000.
  6. Tideland Prius
    16,445
    Yeah they're both top-of-the-line Prius c models in their respective countries.
