Lost All Keys to Prius. Help please
Discussion in 'Gen 3 Prius Accessories and Modifications' started by i32547, Jan 21, 2014.
  1. i32547
    i32547 New Member
    Hi all,
    I've briefly looked around the forum to see if there are any threads with the same scenario, found others who had similar issues, but didn't notice any threads where op had lost all keys to the car.
    The prius is a 2010 genIII uk model. I lost the key to it around three weeks ago. Searched all over for it, safe to say it's gone.
    So after some time wasting, and the prius parked up for three weeks, I'm now trying to resolve this situation without paying the dealer £1700.
    I will try to be as precise as possible in listing what I have tried and with what equipment.
    I have an old lappy with techstream installed and seems operational.
    I have a mini-vci cable not a genuine mongoose cable though.
    Okay, so, I got a replacement blade from the dealer so that I could actually get inside the prius. When I unlock the drivers door with the blade, the alarm sounds for a short while then stops.
    I open the rear hatch, connect a pair of power cables to the battery in the prius boot, and the other side of the cable to another running car battery.
    The prius rear hatch remains open.
    I return to the driver seat of the prius and plug in the mini-vci cable from the laptop to the dlc port of the prius.
    I open techstream on the laptop, press and hold the brake pedal, and click connect to vehicle on the techstream software on the laptop.
    Techstream asks for vehicle details, I input prius 2010 with smartkey.
    Then I go to the smartkey ecu tab on techstream and select utilities then smartkey(or code, can't remember which it says).
    Techstream asks for vin number, input it.
    Then techstream generates a seed code and asks for a passcode.
    I then give the seed code to *#*#*.
    After approx 15mins *#*#* reply with a passcode for me.
    I later noticed that between this point, and the beginning, the power cables got accidentally disconnected from the running car's battery.
    I then entered the passcode into techstream.
    Techstream then proceeded to inform me that the procedure would take 16mins.
    Now, when I try to continue, the box that I clicked greys out and after about 5-10 seconds techstream says that smartkey reset failed would you like to try again.
    I then tried another function (I forget which) on techstream and techstream told me that there was no active communication with the prius. I suspect that the car fell asleep somewhere.
    I then let my foot off the brake pedal.
    I then pressed the start button and tried another function on techstream just to check, and it communicated with the car. This is why I think it fell asleep somewhere.
    I then attempted the whole above procedure again, but, this time the power cables were connected to the battery all the way through, but the other vehicle was not running.
    Also, in this second attempt, before i entered the passcode ( a second passcode that I purchased from sigmabit), I pressed the start button twice just to make sure the car was awake and communication didn't break.
    I got the same result the second time around, failed after 5-10 seconds.
    Now, I'm struggling here. I mean, I haven't even got to the issue of trying to use a used smartkey from my previous prius. It just fails at the reset process. Could someone point me as to some mistakes I'm making? I really could do with some tips here. I'm going to try again now with a different laptop, see if that works.
    iPhone ?
    I'm thinking of using a power probe on the ignition cable to try to get the ignition turned on...because all other reports I'm reading, people are saying that they have the prius in "ready" mode or ignition on...but then, they haven't lost all their keys!
    iPhone ?
  2. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
    I think the car thieves may help. Otherwise I do not think if anybody will give you a recipe how to start the car without keys.
  3. i32547
    i32547 New Member
    Wow!
    iPhone ?
    49,371
    welcome to priuschat! there are a few threads hidden here somewhere, but iirc, the dealer is the only option and people with one key are seriously warned to get a second before it's too late. i hope you have better luck! i wish i had better news for you, perhaps someone will. all i can recommend is shopping around dealers for the best price and pleading your case. all the best!(y)
  5. i32547
    i32547 New Member
    Damn! I am surprised at people complaining about the 300usd fee from the dealer..I wish I could pay that much!! I got quoted £1700. £1700!! Can you believe that??
    iPhone ?
    Oh. And thanks for the welcome bisco
    iPhone ?
  6. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    OP, you might wish to PM a fellow PriusChatter named Patrick Wong. He's very experienced on the Prius family tech side.
    Best of Luck to you!
  7. i32547
    i32547 New Member
    Thanks!
    What is his username?
    The other computer I tried also failed
    iPhone ?
  8. usnavystgc
    3,159
    989
    Tucson, AZ
    Boy that really sucks. Patrick is online now and his username is Patrick Wong. lol. Very knowledgeable.
  9. i32547
    i32547 New Member
    Oh great!
    Thanks
    iPhone ?
  10. bisco
    49,371
    btw, when you lose both keys over here, it's around $1,000. not $300. don't feel too bad.
  11. i32547
    i32547 New Member
    lol
    Thanks! I feel $700 better
    iPhone ?
  12. ckam1989
    ckam1989 Active Member
    185
    358
    Irvine, CA
    2014 Prius Plug-in
    Aww good luck with everything. I hope you get them fixed. :)
  13. JC91006
    16,474
    8,393
    You were talking pounds before at 1700? that's not in dollars?
  14. i32547
    i32547 New Member
    Yep, I was talking pounds
    iPhone ?
  15. JC91006
    16,474
    8,393
    1700 pounds for lost keys....holy crap, that's $3000
  16. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    I think the ECU can be kept awake by pressing the door light switch. I don't know how often, but you might want another person doing it every few seconds while you pay attention to Techstream. The used fob should work fine.
  17. Mr.Electric
    Mr.Electric Member
    287
    102
    San Francisco
    Check out this item
    OBD2 OBD II OBDII ALLIN1 Programmer 4D Chip Smart Key Maker for Toyota Lexus | eBay
    I have one but never used it. I heard they work on Prius.
    If you use the tech stream knock off cable it should work but you need a locksmith ID and to wait 15 minutes then you can clear out the old programmed keys and learn a new master key. It is under smart key > utility. The info above is all relative to the US lock smith rules I do not know what differences exist in the UK
  18. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    If you get really stuck, I have a spare gen III smart key computer (Toyota part # 89990-47050 ) with two mated pristine fobs that I can let go for $250 plus shipping
    MexicanChip likes this.
  19. i32547
    i32547 New Member
    I've tried that orange snartkeymaker... no success...
    iPhone ?
  20. i32547
    i32547 New Member
    will I not need the transmission module computer also?
    iPhone ?
