Lost front splash guard
Discussion in 'Gen 3 Prius Main Forum' started by [email protected], Jun 23, 2021.
  1. Racerman15@comcast.net
    [email protected] Junior Member
    32
    San Francisco
    2020 Prius
    The access panel that drops down to access the oil filter was not installed properly and was knocked off on the road.
    I need to replace it but so far I can find only the entire splash guard.
    Any suggestions as to where I can find just the access panel, roughly 1 foot square?
    kenoarto likes this.
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    o_O
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,057
    785
    Virginia, USA
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,504
    6,594
    Texas Hill Country
    You buy one of the cheap knock off undercovers off of ebay and then remove the access panel and add it to yours (which is all together better with fit and insulation). I used a piano hinge but you could cut it out larger on the plastic hinge side and add a couple of the plastic pop rivets. Part 5141012105 about $60.
  5. Racerman15@comcast.net
    32
    San Francisco
    2020 Prius
    Very good idea! I am thinking of using Dzus fasteners from Pegasus racing.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,498
    Taylors, SC
    I replaced the problematic plastic rivets with M6 rivet nuts and bolts. On the front M6 screws with the small Keps washers that dig in and cut into the soft thin polyethylene shield, I found and use these neoprene backed conical crush fender washers that reinforce and eliminate the long term cutting and tearing of the plastic. The 1/4 inch hole is a good fit for the OEM M6 bolts.
  7. bettergolf
    bettergolf Active Member
    493
    369
    Sanford NC
    Or you could just leave it off. Mine has the entire shield missing....no problems in 4 years...and no loss of gas mileage. Just easier oil changes.
  8. Mendel Leisk
    41,901
    Amayama has genuine underpanel (part no ). For me, price shows as roughly $169 CDN, including shipping, from UAE. In past that's ALL I've had to pay, not extras for tax, duty or whatever.
    Buy Genuine Toyota 51410-12103 (5141012103) Cover, Engine Under, No.1. Prices, fast shipping, photos - Amayama
    The panel will last pretty much forever, IF you don't use that "flap", just remove the whole panel. That's all I ever do, and it's not that onerous, take an extra 5~10 minutes either way. Remove the fasteners carefully, and ALWAYS wash them out with hot/soapy water before reinstall.
    This assumes DIY only, If you're employing "professional" mechanics, they'll break it.
    Part no's for panel and fastener in attached:
  9. Paul E. Highway
    Paul E. Highway Active Member
    209
    129
    Hawaii
    Bought my 2010 used in 2019 with 115K miles and it had no under undercover at all. Don’t miss it, mild weather here, low average speeds, makes working under the car very easy.
  10. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    I'll have aluminum underbody replacements in my car soon, will post pictures once they are installed.
