Lost instrument panel briefly after jump start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PatriciaM, Jan 22, 2025.
  1. PatriciaM
    PatriciaM New Member
    Yesterday was 27 degrees overnight (I hadn't driven it in 3 days either) and my car wouldn't start in the morning. AAA came out for me. But I lost the instrument panel readout for awhile. No speedometer, etc. It did come back after about 20 minutes of driving, which I was doing to charge the 12 volt. What happened????
    51,034
    probably just the low battery. if you are not going to charge the battery, you will need to drive it a lot!
  3. PatriciaM
    I've been driving it, and had the 12v checked. It's good. I'm such a newbie, plus, well, I'm also 82. There is a learning curve, for sure.
  4. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    The problem of switching off the instrument panel on Gen2 in cold weather is caused by the loss of quality of the electrical capacitors inside the panel. It is solved by replacing the capacitors. The search contains topics with photos and videos of the repair process.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,945
    1,900
    NJ-USA
    It sounds like it could be the initial onset of a failing capacitor on the Combination Meter (speedo) circuit board.
    There's a sticky thread about DIY repair at the top of this forum. Another option is to send your CM out for repair (or get an exchange unit) from TexasHybridBatteries.com.
