Lost mpg after having Hybrid battery replaced
Discussion in 'Gen 2 Prius Fuel Economy' started by Llamas07, Dec 17, 2019.
  1. Llamas07
    Llamas07 New Member
    Ky
    I just had a hybrid battery replaced a week ago and I have lost 10mpg since. They are telling me the cause is possibly a dirty throttle body. I'm just wondering if anybody has had similar situation or any other advice.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    What is your current mpg? And how many miles on the car?
  3. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    With what? OEM new or a "rebuilt" of second-hand old modules?
    So, they reckon the throttle body mysteriously gunked up at the exact same time they replace the HV battery?
    In any case, you will need to run three or four tanks of gas and then average the MPG over them to get a better idea of your current MPG. Ideally, you should have been recording your MPG per tank for some months before you had the battery swapped, otherwise, you don't really know what average MPG you were doing.
    Aaron Vitolins likes this.
  4. George W
    George W Senior Member
    911
    514
    San Antonio
    first thing suspected is the last thing changed. Have you used code readers/smart apps before?
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    It's getting cold... MPG's for me are down as well & to be honest, that's the first thing I'd suspect as the culprit. So like dolj mentions up there average this out after a 5 or so fill-ups and see. Secondly, and you may laugh at this, but check your tire pressure. That's a big mpg reducer & the person who did the work on your vehicle may have adjusted the pressure.
    Also just curious. Is this a "rebuilt" battery or new from a Toyota dealer? There are literally hundreds of threads here regarding those rebuilt batteries. Very, very few are complimentary. :(
  6. bisco
    52,371
    welcome to priuschat!
