Lost my key transponder
Discussion in 'Gen 3 Prius Accessories and Modifications' started by B_in_WeHo, May 10, 2013.
  1. B_in_WeHo
    B_in_WeHo Junior Member
    23
    CRAP!!!! I just went to get into my 2012 Prius 3 and my door would not open. I have the little key stub but the transponder must have fallen off. I have searched around the last hour, and plan on continuing to search and hopefully find it. But if I don't find it, I know I am screwed. Do I have any other options besides going though a Toyota dealer?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    By "Transponder" falling off do you mean you lost the entire SKS fob sans the mechanical key? Because if you lost the fob, you are indeed screwed.
  3. B_in_WeHo
    23
    Yes, I lost the black hard plastic part (the remote part) with the buttons. I still have the metal key part that sticks inside of the fob. I can use to just open my door but that is about all it will do. I just called Toyota and they said it is about $300 for a new key fob/transponder or whatever the correct name of it is. And then it is about $150 to reprogram it. At least when they reprogram it they will delete the old code so if someone finds it they can't use it. Luckily my husband has the other one on his keyring. But I just hate knowing that if someone finds my lost one they can drive my car.
  4. The Electric Me
    9,083
    5,798
    That's too bad. Continue searching and hopefully you can find it, that would obviously be the best outcome. Otherwise, I don't think there are too many better options than what you have already discovered. Does that $150 dollar reprograming include programing the new fob and also reprograming your husbands old fob?
    SKS is a nice little convenience, but when something goes wrong it also can certainly become an expensive to deal with proposition.
    I'm just going to hope you find the your original one. When did you first notice it missing? It might be worth it to try to retrace your steps, even call places you visited and ask if anyone turned in a keyfob.
    Good Luck.
  5. B_in_WeHo
    23
    Thanks... I just called another dealer. They quoted me $350 total (tax included) for the transponder/fob and reprograming and they will be able to have the part tomorrow. They will reprogram my husbands transponder/fob to match. He even said that if I should find my old one they will reprogram it again for free of charge so that all three will work.
    Also just an FYI. The guy at the dealer said I am lucky that I only lost the transponder/fob part, that if I had lost the metal key part that sticks inside, that would have been an additional $250.
    The last time know I had it, I used my keys to go check my locked mailbox and take my dogs for a quick walk. I have spent the last hour looking outside and inside. I guess if I do find it, I will just have an extra one. There are worse things.
  6. The Electric Me
    9,083
    5,798
    Wow, that's amazing. The cost of the metal key replacement that is...
    I'm surprised the dealership say's it would cost that much. The metal key part, is just a metal key. Hard to believe that the replacement part itself is very expensive, and harder to believe that cutting the blank to match the existing lock would be anything greater than having any key made anywhere.
    You are kind of cornered when this happens. And it certainly must be a profit deal for Toyota and the dealerships. But at least with the fob, you are dealing with an electronic piece of equipment that must be programmed and synched to your vehicle.
    LOL....The dealership just barely (admittedly not too hard) tried to sell me on an extended maintenance plan. I refused. I don't think it's worth it. But at upwards of $700 dollars to replace a lost Fob and Key? Toyota should offer a Key Fob Replacement Plan. That type of cost is Hybrid Highway Robbery.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Cost probably involved changing out the lock cylinders on both doors, not just replacing the "blank". Otherwise someone wopuld be able to use the found key on the door locks.
  8. The Electric Me
    9,083
    5,798
    Yeah I suppose so. If you wanted to be 100% sure nobody could possibly gain access to your Prius.
    Almost makes me think it might be wiser to remove the actual metal key from the fob and keep it stored securely inside your house or residence. That way if you lose a fob....out in the world, you at least don't have to worry about a "lost" metal key also existing lost out in the world.
  9. CygnusX-1
    CygnusX-1 Junior Member
    But then again if someone does find it "out in the world" provided it isn't in your front yard, they would have to use it randomly in/on every Prius they see to check if it works. Probably more of a fear then actually having someone steal your vehicle. But it would suck if they actually did match it up.
  10. The Electric Me
    9,083
    5,798
    I think the "feared" assumption is that the entire fob, including the metal key, is lost somewhere near your residence. Which since it is labeled Toyota...would make the potential of a problem...much more possible.
    As in this particular case where the OP believes one of the last things she did before losing the Fob was go to the mailbox and take the dogs for a quick walk.
    Yeah, if you lose your FOB randomly at a distant Mall, or at the coast or 100 miles away? I don't think you have much to worry about. You would be sheltered by the reality that the world is a big place and there are a lot of Prius out in it.
    Basically the whole situation just kinda sucks.
  11. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    Hurry and buy yourself a replacement fob on eBay and have the original and replacement fobs reprogrammed. I think this might deactivate your old lost one. Someone chime in if im incorrect.
  12. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    BTW I bought a replacement for $52 shipped on eBay and had it programmed by Pop-a-Lock, Los Angeles for $50! Total for replacement was $102!
  13. B_in_WeHo
    23
    THANK YOU SO MUCH!!! I just bought one on ebay for $48.48 I just called Pop-a-Lock and they quoted me $60 to reprogram both fobs.
    I park in a large parking garage and I backed my prius as close to the wall behind my car and I put my other car in front of it. So if someone found my fob they can't get my car out.
  14. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    I'm sure you got the right fob but just in case:
    FCC ID: HYQ14ACX
    IC:1551A-14ACX
    COFETEL RLVDE1408-0265
    DENSO 14ACX
  15. B_in_WeHo
    23
    Yes, the one I got was - TOYOTA KEYLESS REMOTE HYQ14ACX SMARTKEY.
  16. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    Did you buy a new or used fob on eBay? I bought a used one on eBay and Pop-a-Lock couldn't program it. But that was 2 years ago and maybe they know a lot more now.
    Mike
  17. The Electric Me
    9,083
    5,798
    Yes, please let us all know how this works out.Very nice to know there are other options out there other than the dealership if a similar happening should occur.
  18. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    I purchased a used one. There is always a chance that it may not work but the Pop-a-Lock that I used actually works with a local Toyota dealership in Los Angeles. It's all about finding a locksmith who has the experience with programming Toyota SKS'. I called around and asked several locksmiths if they knew what they were doing and West LA Pop-a-Lock was the only company who could give me a confident "yes".
  19. B_in_WeHo
    23
    I called Pop-a-Lock last night (before I bought the one on ebay) and I asked them if they had the fob/transponder and they said that they can get them. I asked how much for it. They told me it would be $400. That was more than the dealer. So all they probably do is get it from the dealer add on their profit and sell it to me.
    I am still torn what I should do. Since I hate knowing that someone could drive off with my car if they find it. The person that I got the one on ebay from is about an hour away from me. I emailed them and asked them if I could pick it up in person. They replied that they would not be available this weekend. So I am not sure when I would get it. My husband wants to still go to Toyota today and get the factory one. He is paranoid having pop-a-lock mess with the computer. If they do something and mess it up. The service advisor at Toyota told me that if I found my old one they would reprogram it again for me - for free. So I was thinking when I get the one off of ebay go back to Toyota (telling them that was my old one that I found) and have them reprogram it and then I will just have an extra one. That is not the worst thing to have. I also feel guilty that they ordered the part for me, that I should buy it.
  20. Mendel Leisk
    38,653
    Just have to say, the prices Toyota's charging for replacement fobs are onerous, they really have a captive market, taking advantage.
    Just like their Tire Pressure Monitor System: replacement sensors are way to expensive/complicated.
