Lost Only Key, What Parts Do I Transfer From Another Prius?
Discussion in 'Gen 2 Prius Technical Discussion' started by Phildo, May 1, 2017.
  1. Phildo
    Phildo Active Member
    138
    109
    Perth, Western Australia
    i-Tech
    Car: 2008 Prius NHW20
    Problem: Only had one key, and now it’s been stolen.
    I have a 2008 Prius which is used as a taxi. Someone has stolen the only key that I have for it.
    I need to get the car running as soon as possible.
    I have two other identical Priuses that I can temporarily remove parts from to get the taxi going.
    I have been told to transfer the ECU and key from one of the other cars. All keys are black (ie no silver logos).
    Is that it? Anything else to transfer?
    Any tips on where the ECU is, and how to remove it?
    Note: I do have a Mini-VCI cable but haven't used it or Techstream yet.
    Thank you.
    #1 Phildo, May 1, 2017
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    #2 Beachbummm, May 2, 2017
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,441
    3,332
    Madison, Wisconsin
    You will, of course need to get replacement fobs.
    Checking a different thread on PriusChat says....
    "There is no need to swap any hardware if you have Techstream and a valid passcode. "
    You will need to use the key programming function of Techstream. It will generate a 96 digit hex code. Using this hex code, you then have to pay a service to generate a passcode (reseed code) for you. These services are readily available to locksmiths with security credentials. For the average Joe, usually you end up turning to online services outside the US.
  4. Beachbummm
    1,160
    392
    will the purchased pass code work with the "amazon/ebay" techstream or does it only work with the real and registered software?
    and where do you get this code?
    I also need to reprogram my master fob to get the SKS to function again
  5. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    You basically will be wiping all keys and starting over.
