Lost only working FOB now What?
Discussion in 'Gen 3 Prius Technical Discussion' started by Ritzy4runner, Nov 4, 2022.
  1. Ritzy4runner
    Ritzy4runner Junior Member
    36
    Bremerton, WA
    I searched and found nothing on this. Only have a single FOB now and it died. Have to insert it into the KEY slot to start. How can you program a new FOB with no working FOB? I also understand you can not take "USED" FOB and reprogram it? Anyway I do have a 2007 with the silver back (smart key) Funds are super tight but would like to have the smart functions back. Thanks for any and all help
  2. Tombukt2
    Tombukt2 Senior Member
    8,923
    1,553
    Durham NC
    I been doing same for months you know the pick up sensor for alarm is behind rear cup holder and on trunk floor opposite battery tray they're white with red markings on them . And numbers on them that probably corresponds to the system and fob . . They're are locksmiths out they're that know what's happening . Inside remote is a sticker you need crack open fob and take a good picture of sticker this is what the key guys need to program a green fob board . The transponder chip is working great I slot or docked it turns red key off and allows start . Don't loose that lil chip .if you do you're toast look online for a break down of remote and location of transponder chip lil black thing VS green board with battery . The part you need renewed. I hope you understand .
  3. JC91006
    16,477
    8,394
    Have you tried changing the battery on the FOB?
  4. Michael Wood
    Michael Wood Active Member
    179
    118
    Boston, MA
    2020 Prius Prime
    Sounds like you just need a new battery in your inoperative FOB. Buy a new battery CR1632 at Walmart. The directions for replacing the battery are on youtube.
    Get your FOB working and then you can have a duplicate made - don't go to the Toyota dealer. The cheapest I found in my area for an independent locksmith was $235 for a replacement FOB. Call around.
  5. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    "Fob" is not an acronym, so why capitalize it?
  6. bisco
    49,387
  7. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    o_O
  8. Tombukt2
    8,923
    1,553
    Durham NC
    If battery or board is dead then you slot the remote .and beeps return and car can start..wen green board is operational seems like car starts with fob in pocket in hand etc . No need dock
  9. ChapmanF
    15,466
    Thank you! I've been fighting the urge to say that for years!
    Unless we're talking about shipping tariffs, it's just a fob.
    CR94 likes this.
  10. JC91006
    16,477
    8,394
    FOB , That's fresh of the boat
  11. Tombukt2
    8,923
    1,553
    Durham NC
    These would be long off the boat at least mine would be so long it is wore out and broke.
  12. bisco
    49,387
    punt?
    Grit likes this.
  13. Tombukt2
    8,923
    1,553
    Durham NC
    If he's still alive talk to all lock and key in Maine That's a state in the United States up north this guy will tell you what he can do and it's a lot or it used to be a lot.
  14. bisco
    49,387
    vacationland
    Grit likes this.
