Lotus Range Extender
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Dec 11, 2009.
  1. bwilson4web
    16,352
    First clued by Autospeed.com, they identified the source of this Lotus article:
    proActive Issue 34
    A 'range extender' is a small engine-generator set designed to recharge batteries of an electric vehicle and extend the range. It charges the batteries so the vehicle continues to run. Some salient points:
    • gasoline engine - they didn't go diesel and explained why
    • 35 kW (47 hp) - more than enough for a Prius sized vehicle, it would extend to larger sedans, van, and possibly some SUV sized vehicles
    I wasn't 'inspired' by their engine technology but since it runs at a constant speed, it doesn't have to inspire. It only has to be efficient in the limited power range and that means a lot of 'neat' things variable power, gas-diesel engines require to remain efficient are not needed. The surge power is provided by the battery-motor, primary power system.
  2. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I saw the news in September.
    Frankfurt Preview: Lotus develops a range extender engine — Autoblog Green
    An interesting thing is the engine does not have a cylinder head gasket.
    "The Range Extender features a novel engine architecture incorporating a monoblock construction that blends the cylinder head and block together eliminating the need for a cylinder head gasket, improving durability and reducing weight."
    Ken@Japan
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    :) I owned a Can Am motorcycle with no cylinder head gasket, even though the cylinder head was removable. But it was an air cooled 2 stroke engine.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    What is old is new again.
    [ame="http://en.wikipedia.org/wiki/Offenhauser"]Offenhauser - Wikipedia, the free encyclopedia[/ame]
    "Another reason for the engine's success was reliability; unit construction (no separate cylinder head) meant the engine was not vulnerable to head gasket or cylinder stud problems and allowed for higher cylinder pressures."
  5. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Honda has one too. :D
