Loud bang and Abs light, warning light on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Allyssa Cole, Mar 10, 2021.
  1. Allyssa Cole
    Allyssa Cole New Member
    Altamonte springs, Fl
    Last night i was driving down the highway at 65 mph, heard a loud bang that sounded like someone hit me, (nobody hit me) and then my Abs light, warning light and traction light came on.. Any idea what happened? I have a 2014 prius three..
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Sounds like a hole in your engine
  3. ChapmanF
    15,569
    Where would you say you heard the bang from? Ahead of you? Behind you?
    The lights that came on suggest the skid ECU has some information for you about what happened. Why not ask it?
    If you don't have a scan tool that can read those codes, you can use the jumper wire and count-light-blinks method, and post the codes you get here.
    If you read blink codes, there's a chance they'll just tell you there are codes to be read from other ECUs in the car that don't participate in the light-blinking trick, so somebody with a scan tool would need to get those. But anyway, it starts with getting the ones you can get.
