Loud droning noise when accelerating
Discussion in 'Gen 2 Prius Technical Discussion' started by tylerjames, Dec 10, 2018.
  1. tylerjames
    tylerjames Junior Member
    26
    north bay
    hello, louder than normal droning when accelerating. No issue with speed, and no lights come on in my 07 prius with 180k on it. Ideas? Was hoping to go on a 1000 mile road trip next week and this happened..
    52,401
    bad exhaust system?
  3. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    ditto on exhaust leak
    Paul
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    If it changes pitch with the engine speed (which can stay the same as the vehicle accelerates due to the CVT-like-drivetrain), I agree, it's mostly likely your exhaust, this is where I would look. Pretty easy to jack up the car and then examine the exhaust system using a flashlight to see if there are holes.
    If the droning changes speed with the vehicle speed but not the engine speed, most likely cause is wheel bearings.
    Less likely is a bad motor mount. I've had a car where you could hear and feel the vibrations of the engine on acceleration when the motor mount failed (metal-on-metal inside the motor mount). This you can tell because it happens more at the start of accelerating, and especially when accelerating rapidly from a stop due to more g forces on the engine. The sound goes away or diminishes a fair amount as the vehicle picks up speed.
    #4 Kevin_Denver, Dec 10, 2018
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    How does your battery level look when this is happening?
