Loud engine noise
Discussion in 'Gen 2 Prius Technical Discussion' started by Laurenlauren1990, Sep 28, 2019.
  1. Laurenlauren1990
    Laurenlauren1990 New Member
    NC
    My 2008 Prius has been making a loud noise when engine cuts on/battery is charging.
    I can’t really pinpoint where it’s coming from I just know it’s louder than it used to be.
    No driving issues and no check engine lights. It’s just loud.
    230k miles, regular maintenance and oil changes.
    Any ideas?
  2. dolj
    dolj Senior Member
    8,558
    4,348
    Wellington, New Zealand
    Maybe you have corrosion eating away your exhaust system???
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Or stolen Cat?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Ever run the motor dry of engine oil or so low nothing showing on the dipstick?
  5. bisco
    52,390
    heat shield/motor mount?
  6. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Better change the oil and look real close for metal, same with the transaxle, it could be MG1 or MG2 stator broke lose and is rubbing the case! In that case you will probably find bits of wire and insulation in the oil...but then again you would've had some serious DTC's by then as well.
