Loud engine
Discussion in 'Gen 2 Prius Technical Discussion' started by jbct, Jul 28, 2022.
  1. jbct
    jbct Junior Member
    29
    CT
    My 2008 Prius has 165,000 mi. A few months ago, prior to AC season, the engine started running a bit louder than it had been. I'm only getting 39 MPG. The following were checked and are good: tire pressure, oil level, coolant levels, air filter. I'm thinking maybe changing the transmission fluid or both coolants. Which one would be causing the louder-than-normal engine?
    Meg&Bear likes this.
    52,006
    might be a leaky exhaust manifold
    Meg&Bear and WilDavis like this.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Back in January, some light-fingered, slimy shyte-for-brains stole ChugyPyg's catalytic-converter and the immediate effect on the noise-level of the running engine was quite noticeable. :eek: There was a rash of such crimes in this area back in January. It's 3 am. Do you know where your catalytic-converter is? :whistle::whistle::whistle:
  4. PriusCamper
    PriusCamper Senior Member
    12,796
    5,184
    Pacific Northwest, USA
    How much louder? Like really loud? Or just sort of loud? And as per @bisco comment... Does it smell like an old 1970's car in the engine compartment when engine is running?
  5. bisco
    52,006
    if by 'louder than normal' you mean a little more rpm, could be the hybrid battery
  6. jbct
    jbct Junior Member
    29
    CT
    Alittle louder but noticeable from what it had been. Cat. converter is OK. No smell from the engine compartment. MPG down to 36.
  7. jbct
    jbct Junior Member
    29
    CT
    On the screen Energy Monitor, under Battery, the green bars are at about 90%. The blue bars at 80%. MPG are now down to 36.
  8. jbct
    jbct Junior Member
    29
    CT
    How can I check that?
  9. monoshock
    monoshock Member
    59
    26
    Rocky Top TN
    My guess is battery.
    Time for a NexCell kit.
  10. bisco
    52,006
    you would have to start with the manifold, feeling for escaping air, and work your way back to the muffler
  11. mr_guy_mann
    mr_guy_mann Senior Member
    4,050
    1,976
    NJ-USA
    Get a length of small hose (around 1/4" diameter, maybe 3 foot long). Hold one end in an ear while carefully moving the other end around exhaust system parts. When you get the hose near a leak, it will sound much louder . You need to keep the engine running. You can put the car in "maintenance mode", or try turning the heater up to hi-full hot.
    You need to safely raise and support the front of the car to be able to check everything- especially the spring loaded flex joint between the exhaust manifold and the catalytic converter. The "donut" gasket can wear and leak. If so, get a new one from Toyota- that fits and seals best.
    It can help to have a helper use a heavy leather glove to "cap" the end of the tailpipe and force more exhaust out of any leaks - do that for a few seconds at a time then pause so you don't get a burned hand.
    Meg&Bear and douglasjre like this.
  12. jbct
    jbct Junior Member
    29
    CT
    Update- I usually drive with the windows up hence the noise seemed to be coming from the engine. One day with the windows down I realized the noise was coming from underneath the car. In short, cat converter was on its way out. Replaced it. About $1000, ouch.
    Meg&Bear, douglasjre and bisco like this.
  13. bisco
    52,006
    you can sell the old one for about the same price; win/win!
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Surprised you found the OEM cat it’s been on back order for a long time last I heard.
    Hope you didn’t pay $1000 for an aftermarket $125 cat. Cost $80 to weld it up.
  15. lexidium
    lexidium Active Member
    298
    140
    manchester
    I just had noisy engine. It turned out I needed a new water pump.
