Loud humming noise from air conditioner
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cooldyood, Jul 28, 2021.
  1. cooldyood
    cooldyood Junior Member
    45
    Wash DC
    My 2006 Prius with 240k miles makes a loud humming noise when the a/c is turned on. The noise stops if the a/c is turned off. I did some reading online, and at first I thought it's the blower fan but then realized that the noise is coming from around the engine area, not from near the glove box.
    Having seen this video I believe it may be a compressor problem. Especially since it is not a constant noise, it goes in and out, maybe from the compressor repeatedly trying to engage?!
    Before spending $$ on diagnostics and repairs, I wanted to get you all's thoughts - am I on the right track here?
    Thank you.
  2. ChapmanF
    15,569
    Under some load conditions, it's normal for the compressor to cycle on and off.
    How long have you had the car?
    Have you asked for diagnostics from the HVAC system? (Hold the fresh/recirc and auto buttons while turning the car on, then watch for 2-digit codes at the top left of the MFD screen.)
    SFO likes this.
  3. cooldyood
    45
    Wash DC
    I got the car used 7 years ago. Thank you for the diagnostic tip - the codes are 33, 42, 43.
    49,445
    the compressors are noisy to begin with. especially with the hood up. the faster they run, the noisier they are.
    if the sound is increasing, it could mean it's on its way out
  5. cooldyood
    45
    Wash DC
    The air is only mildly cool, is that another indicator of a bad compressor?
  6. bisco
    49,445
    just one possibility. it's an expensive fix, so you want a competent diagnosis.
  7. cooldyood
    45
    Wash DC
    Gotcha.. Do the diagnostic codes 33, 42, 43 mean anything useful?
  8. bisco
    49,445
    idk, you can look at the service manual, or perhaps someone else knows
  9. ChapmanF
    15,569
    It's worth mentioning we've got a wiki page where Elektroingenieur kindly put together lots of information on getting access to the Repair Manual and other tech info, both through Toyota's inexpensive online subscription or through other options like a local library where you may have access for free.
    I think the HVAC two-digit codes xy just directly correspond to DTCs B14xy (the blink codes for some other things in the car are not always so tidy, and have to be looked up in tables to find the corresponding DTCs).
    So those are B1433, B1442, and B1443. Interesting, but probably not to do with the compressor hum. 33 and 43 are both about the servo that controls which air outlets you have selected (43 is an electrical issue detected with that motor, and 33 is about the sensor that detects its current position). 42 is the same kind of thing, but for the servo that controls the air inlet (fresh or recirculate).
    Those would be worth tracking down eventually, but maybe they aren't your chief concern right now if you're worried about the compressor.
    But there's also the dog that didn't bark: you don't have any codes there about the compressor. That doesn't always mean there isn't one, but it can be a good reason to think about how sure you are that there is.
  10. cooldyood
    45
    Wash DC
    Thank you, that's a lot of great info right there! To your last point - my concern isn't the compressor, or any other specific part. It's the noise and less-than-cold air. I had the refrigerant refilled a couple of weeks ago, so I doubt it's a refrigerant issue.
    Thanks again.
  11. bisco
    49,445
    did it improve after the refill?
    could be a leak? did you have it filled at a toyota dealership, or qualified prius shoppe?
  12. cooldyood
    45
    Wash DC
    It turns out the noise doesn't go away when the a/c is turned off, but it does go away when the fan is turned off.
    Also, per suggestion by @ChapmanF in post #2 and my response above, the codes aren't pointing to an a/c issue.
    Is there a similar diagnostic sequence to test the blower fan?
    Just to reiterate, the noise is definitely not coming from near the glove box, it is somewhere in the driver side area of the engine.
  13. bisco
    49,445
    is it the cooling fans on the radiator?
    maybe not a fan at all, you've got several pumps in there. coolants, brakes, etc.
  14. RobertK
    RobertK Member
    128
    40
    Norfolk, VA
    I had this problem and traced it to one of the radiator fan motors. I replaced the radiator fan assembly and the problem went away.
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
  16. edthefox5
    10,096
    4,805
    Clearwater, Florida
    No its an indica
    If you had the refrigerant refilled last week that means you have a leak. If it was empty it didn't evaporate. You didn't use one of those Auto parts store fill er up cans did you? I assume so because if an AC shop did it they would have put dye in and found the leak.
    Be aware operating the compressor with low refrigerant is very bad for that very expensive compressor.
    If you think you have a noisey fan take the black plastic cover off the top of the rad. You can then look down and see both fans. The compressor is low on the passenger side. In Max AC mode both fans should be running. Helps to have a flashlight. See which one is loud.
    Don't see alot of rad fan issues on a G2. Can't remember a post about one. Unlike alot of other cars. Mine are going on 14 years old still OK.
  17. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    What was the cost? Did you DIY?
  18. ChapmanF
    15,569
    One of my radiator fans is kind of rumble-y recently. I haven't cared enough so far to grab a stethoscope and figure out which one. Hmm, maybe I'll go do that now....
    Edit: stethoscope says my rumble-y one is the right one, a/k/a the one with the blue wire, a/k/a the "cooling fan". Not the left, green-wired, "no.2 cooling fan". (At least Toyota moved away from the previous-generations naming, where one was the "radiator fan" and one the "condenser fan" even though they were both equally behind the radiator and condenser.)
    Edit again: ok, weirder, in the Repair Manual diagrams, the right fan is the "no. 2 cooling fan". Looks like the wiring diagram and repair manual disagree as to who is "fan" and who is "no. 2 fan".
    #18 ChapmanF, Aug 10, 2021
