Loud, metal-scraping noise & foul exhaust smell when start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yogahelps2, Nov 18, 2018.
  1. yogahelps2
    yogahelps2 Junior Member
    My 2010 Prius with 112,000 miles occasionally (happened once two weeks ago, and again today) makes a loud, meta-scraping noise when we start it. The foul exhaust smell sometimes occurs without the loud noise. We just had it in for an oil change a month ago and there are no warning lights on the dash that come on when this happens. Please help. Thanks.
    51,155
    couple known issues:
    there is a cold start knock sometimes, if you previously shut the engine down before it had fully warmed up, like moving it around the yard and shutting down immediately
    the egr circuit probably needs to be cleaned. do this before the head gasket blows
    this problem tends to show itself around 100,000 miles
  3. Mendel Leisk
    40,586
    Stupid question but anyway: you've checked the oil on the dipstick?
    If it was severely low there'd be a warning about oil pressure (red, looks like a genie's lamp?), but who knows.
    Also, who did the oil change?
  4. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    If it is "rotten egg" smell, it could be your catalytic converter. This is designed to convert hydrogen sulfide in your engine's exhaust into sulfur dioxide. The rotten egg smell could signal that your “cat” isn't working as it should. This does not explain the other part of your post.
