Loud noise and little shaking when car shifted to Engine from Battery
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ohid, Mar 6, 2022.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    My car is making loud noise and little shaking when it is transferred from Battery to Engine. The sound is prominent at idle or traffic jams. At running, the sound and shaking was not felt.
    No codes, no misfired, no oil consumption and no coolant lose.
    Its Prius v 2015 at 97k km. Bough it at 80k km two years ago. Mainly city driven and mostly run on short trips less than 5 km.
    Any remedial suggestions are appreciated.
    #1 Ohid, Mar 6, 2022
    48,962
    have you cleaned the egr circuit?
  3. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Not yet. So far I cleaned throttle body, injectors. Spark plugs changed two years ago.
  4. Tim Jones
    Tim Jones Senior Member
    1,684
    547
    SE Texas
    2011 Nissan LEAF
    Or your transmission is going out....
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    I think not likely. It only happened when battery was at low limit and engine kicked on.
  6. Tim Jones
    1,684
    547
    SE Texas
    2011 Nissan LEAF
    Ok.... guess you have it all figured out.
    Why are you on here asking questions when you already know what's wrong?
  7. Mendel Leisk
    38,232
    Early? In your hands? Any special reason?
  8. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Sorry, if there any solid reason my transmission is going to die. Transmission oil changed two years ago. Still its so smooth like butter. No issues regarding transmission so far.
    Have you faced this problem and your transmission was weaker?
  9. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Workshop told me to do that. It was not so bad.
  10. bisco
    48,962
    can you post a sound recording?
  11. jj3480372
    jj3480372 Junior Member
    jj3480372
    2013 Tesla Model S
    Touring + Tech
    You need to change the plugs
    TECNO KE5 ?
    Ohid likes this.
  12. Tim Jones
    1,684
    547
    SE Texas
    2011 Nissan LEAF
    Same thing my trani did before it set off codes.....and the light on the dash..........
