Loud noise followed by yellow triangle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seanmc980, Jul 24, 2018.
  1. Seanmc980
    Seanmc980 New Member
    Virginia
    So, I was driving to work this morning and I heard this loud sound coming from the back trunk area.. it sounded almost like someone was crumbling up a cigarette cellophane wrapper only much louder and it lasted for maybe 5 seconds.. this was quickly followed by a yellow triangle "check hybrid system".. I about died on the spot.. pulled over and cut the car off.. after doing some research, and not coming up with much, I tried clearing the warning by restarting the car 3 times.. this didn't clear the alert but did create a consistent noise that I could track.. I ripped the trunk apart and found the source of the noise.. the HV battery blower is making a light noise, and appears to be running pretty slow.
    I'm broke as a joke and cannot afford a $125 Toyota diagnosed, plus whatever they charge from the parts.. I looked up a YouTube and the replacement looks simple, and a used part on eBay is $40-60. So I took my chances and drove it the rest of the way to work.. about 5 minutes before I arrived, a few more lights lit up on the dash.. the traction light, and what I think is the brake fault light..
    Is it normal if the battery fan goes bad to throw the alert for "check hybrid system"? I'm assuming if the fan isn't running right, it's causing the EV to overheat..
    Also, is it normal for other dash lights to come on, if the "check hybrid system" comes on? Those lights did clear when I restarted.
  2. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    If you're lucky you didn't make it worse by driving it further... If you're lucky your cooling fan just sucked in something that's clogging it and you can clean it and fix yourself at no cost. If you're currently too broke to spend $125 on diagnosis, you don't want to know about repair costs if you aren't lucky. If you have basic automotive repair skill you may be able to fix it inexpensively... There's lots of info on this site. Don't drive your car until this is figured out!
    RMB and Mendel Leisk like this.
  3. Seanmc980
    Virginia
    Thanks for the reply.. it took over 24 hours for a moderator to approve this thread, so I had it figured out before hand.
    I was able to give the fan a couple good whacks and it kicked right on, I'm planning on pulling and cleaning it this weekend.
  4. Mendel Leisk
    38,735
    ^ What he said. Don't be penny wise and pound foolish (Brit currency adage). Try checking/cleaning the hybrid battery fan and associated ducting, before driving it any further. @NutzAboutBolts has a good video on it here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    My only comment on the video: you can avoid pulling off the rear seat bottom; just push a space between rear seat and back, at the hybrid fan intake grill, and reach in there with a 12 mm socket on an extension, remove the single hold-down bolt. Take care not to drop it.
    You can check/clean the fan without complete removal. Also, when reinstalling the hatch floor, leave most of the fasteners off, the ones that push into the top of the hybrid battery. This'll make it a lot easier to pull off next time.
    NutzAboutBolts likes this.
  5. bisco
    49,507
    welcome!
    pretty unusual, how many miles on her?
    your last two sentences, yes and yes.
    all the best!(y)
  6. PriusCamper
    11,106
    4,520
    Now that I've cleaned a few fans with and without complete removal I'm thinking it'd be a way more efficient and more thorough clean up job if I popped off the clip holding the plastic squirrel cage fan part and scrubbed it in in hot soapy water. Is that the way you do it? Is that clip / plastic relatively east to remove?
  7. Mendel Leisk
    38,735
    Complete removal of the fan is another level of difficulty, and not really necessary, my 2 cents.
    I cleaned the fan in place, with a Q-tip, which fits between the blades just snug. I ran one of those duster boas through the (removed) duct, work then just blew out the whole area with my wet-dry vacuum on blow.
    PriusCamper likes this.
  8. PriusCamper
    11,106
    4,520
    Thanks... I'll try the q-tip idea next time... Probably have to go thru alot of q-tips though. but I bet it fits in between each blade better than the rag I was using, which only made it 95% clean. Sure wish it was faster to just pop the squirre cage off and wash it with the force of hot water and soap. But like you said, it seems like another level of difficulty.
  9. Seanmc980
    Virginia
    I can't make this stuff up... 20180726_180820.jpg 20180726_180825.jpg 20180726_182627.jpg
    mjoo, RMB and Mendel Leisk like this.
  10. Seanmc980
    Virginia
    It's a scary thought to think that the only way into the squirrel cage is from the HV battery.. guess I should rip this cover off and inspect for any damage.
  11. Mendel Leisk
    38,735
    That's yours right? Yikes!
    There's air exhausts under the hatch floor, both rear corners. There's flaps over them: maybe the rodents are coming in through there.
    They do call the fan a "squirrel cage"...
  12. PriusCamper
    11,106
    4,520
    wow.... Just wow... Maybe previous owners had some clever kids? Or maybe there's some plastic barriers that have been chewed thru by critters? If you have the right vacuum cleaner attachments you might be able to do it without pulling the hybrid battery but who knows... Please post more pictures... I'd love to know more details about how/what happened?
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    That is scary.
    Eat, Spit, Be Happy?
    What type of advertising slogan is that?
    I have a question.
    Are the seeds you are finding complete? That is not just the shells but the entire seed?
    My fear obviously would be some type of rodent infestation and rodent damage.
    But if that is the case, I'd also expect you'd be finding more unpleasant evidence of rodent existence. Starting with, a lot of 1/2 eaten sunflower seeds.
    What do you do? I'd continue to clean, inspect and hope for the best.
  14. Mendel Leisk
    38,735
    I've got rodent mesh on the engine air intake, the cabin air intake, but not the hybrid battery air exhausts. Thinking maybe I should get on that...
    Not sure if this is 2nd or 3rd gen, anyway they are similar. There's an exit air flap like this on both sides:
  15. Seanmc980
    Virginia
    All the seeds were intact.. I had the full bag in the center console, so that little bastards chewed a hole in the bag and brought them one by one into the fan.. I found a nest under the back seat.
  16. jerrymildred
    jerrymildred Senior Member
    11,513
    14,118
    Tampa, FL
    I'm glad they were eating sunflower seeds and not your wiring!! :eek:
  17. The Electric Me
    9,083
    5,798
    Too bad. I was trying to be optimistic.
    Guess they like take out.
  18. PriusCamper
    11,106
    4,520
    Yea... What's so weird is that their weren't any already eaten hulls in the pics... How long was the package in there for? In my experience they work on getting into cars in the Winter when its cold out and have no interest in such spaces in warmer months.
  19. The Electric Me
    9,083
    5,798
    Yes, that's why I was trying to be optimistic. NOT seeing any empty shells or 1/2 eaten seeds. I was hoping that perhaps it wasn't a rodent infestation symptom.
    Good god, how stale do those seeds have to be to be turned down by hungry rodents? They disliked them so much, they were throwing them in the rodent equivalent of a mulcher.
  20. PriusCamper
    11,106
    4,520
    Yep... What I enjoyed most about this post is it gave me something to ponder while gardening today!
    This is yet more proof that cars will last way longer and will have way fewer problems if you keep them super clean and free of clutter... Don't be messy or you'll attract an even bigger mess!
