Loud noise from under the hood when engine turned off..
Discussion in 'Gen 3 Prius Main Forum' started by mnsweeps, Mar 19, 2013.
  1. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    what is this loud sound coming from under the hood when you turn off the engine? I see a lot of threads when I Googled but wanted to get first hand info from experts here.. :) Mine is 2012 Prius with 19500 miles on it.
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    you're probably covered under your warranty take it to Toyota let them look at it tell them the signs let them fix it
    do you have any lights that come on your dash when that happens?
  3. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    Nope...everything is good...sound goes away after a few seconds and car goes to sleep ..
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    Can you describe the noise? Maybe it would help to analyise the condition. Sometime the A/C will make hissing noise when the pressures in the system are equalizing after shut down.
  5. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    I will record it the next time and post the file here...
  6. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Do you put the car in Park by pressing the Park button before shutting down the car using the Power button?
    If not, then I've noticed that the car can make a noise when engaging the parking pawl before/while the car is shutting down.
    mnsweeps likes this.
  7. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    Good point. What's the ideal situation? Put the car in park and then shut off engine?
  8. xliderider
    7,872
    3,116
    Honolulu, HI
    Yes, but a lot of people bypass this process because the car will automatically put the vehicle in Park before shutting down. I've noticed that a message will flash briefly reminding you to put the vehicle in Park before shutting down on the MFD, or was it the Navigation screen?
  9. xliderider
    7,872
    3,116
    Honolulu, HI
    The next time you power down your Prius, try pressing the Park button first. I suspect that that will stop the "thunk" noise you are hearing when you power down your Prius.
  10. BZzap!
    1,607
    877
    With a post lke this, I'm thinking that something out of the ordinary is happening. Evidently the OP's post was inquisitive and not intended to suggest something was wrong with the car. If indeed the noise is just the park mechanism, I would hope that's the case. After clocking 20,000 miles on the car, intuition would point towards "Normal".
