Loud noise in engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TravisBe, Sep 22, 2018.
  1. TravisBe
    TravisBe Junior Member
    22
    CA
    When I turn my car on (2008) I get this jet engine sound from the radiator area. It's not there all the time, but I would say most of the time. Is it normal?
    I have an MP3 of the sound, but the forum won't let me upload it to show you.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Have you had anything done to your Prius engine coolant loop?
    What condition is the water pump in?
    49,693
    how many miles on her?
  4. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Driver side under headlight coolent pump. Normally it after you turn the car off. If it only when engine on? Or either?
  5. TravisBe
    22
    CA
    I topped off the coolant this morning in both reservoirs. It's been low for a while. As far as I know the water pump is working fine, but I don't really know how to check. The car is at 192,000 miles. I've owned it since 160,000. Other than this roar coming from the engine when it's running the car seems to be working fine. The sound goes away from time to time when the engine goes completely quiet, but comes back to life for most of the time it's running.
  6. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    What condition is the belt in?
    Any pink crystals around the pump or pulley area?
    If you topped up the coolant, did you do this in the radiator or the overflow container?
  7. TravisBe
    22
    CA
    I'm not seeing any pink residue, but I'm still looking around. There are a couple spots near the closest belt wheel that look more like pink paint than crystals. I filled the container in the front of the engine and the one beside the battery.
    Raytheeagle likes this.
  8. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    All you filled was the overflow reservoir, and not the radiator directly ;).
    Take the plastic shield off in front of the reservoir to reveal the radiator cap and see where the fluid level is. Add directly here until no more liquid will go in.
    On the drivers side of the radiator is a bleeder to get any entrained air out. Use this as well to remove the air;).
    Good luck and keep us posted (y).
    edthefox5 and Jmack111 like this.
  9. TravisBe
    22
    CA
    I thought I did that. I had to take the big plastic shield off the front of the engine (and broke two of those plastic screws) in order to check the radiator coolant level. Either my angle and light was bad, or the reservoir was damn near empty. I'll have to take a look for that air bleeder. There was a cap on the passenger side right next to the reservoir that said to open it before filling and I got an air hiss when I opened it.
    Anyways, I drove for 5 minutes to get new air filters (my cabin filter looked like a tree was taking root). When I turned on the car I got that roaring sound. When I got going I decided to turn off the air conditioning and the roar went away. I parked in front of Autozone and played with the A/C for a few minutes and it seems that the sound is the big fan in the front kicking in when the A/C is on. As soon as I turn it off it goes away. I pulled into the driveway and got out which is where I notice the roar the most. This time I parked with the A/C off and the car stayed quiet on battery for a couple minutes. I turned the A/C back on while idle and the engine roared back on again. Now that I think I've discovered the source of the roar, my follow up question is: is this normal behavior? If so, I'll ignore it and focus on other issues.
  10. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    How many miles on Your Prius? How fast does the hv battery cycle?
    When the ac runs it taxes the battery heavy and if the battery is weak, it’ll make the engine run more and require more load.
  11. TravisBe
    22
    CA
    It's at 192,000 miles and as far as I can tell it's on the original battery. I bought it at 160,000 miles. What do you mean by "cycle?" How often does it make that buzzing noise?
  12. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    If you are in a drive thru line, how long does it take for the battery to deplete?
    If quick, the battery is aged and will tax the engine.
  13. TravisBe
    22
    CA
    I have to take one of these air filters back to the store to trade. When I come back I'll let it sit and time it and let you know.
  14. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    You can try it with the ac on, and that load should be telling on how long it takes.
  15. TravisBe
    22
    CA
    How long should it run with the a/c on to make it a good test? I drove it without a/c for 5 minutes, regenerated 75Wh, and let it idle in the garage for 10 minutes without the ICE coming on.
  16. TravisBe
    22
    CA
    Not to derail my own thread, but I got a new sound coming from the engine (or just finally noticed it). I noticed it while my car was sitting idle in the garage waiting to see if the ICE would come on. I might have heard it while the car was in motion too. This YouTube video isn't my car, but it's the exact same sound (starts around :15 but you can really hear it at :50). The car in the video is making that pumping sound continuously while mine is only occurring for two seconds every couple minutes. What is this?
  17. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Test should be done with the car on and sitting still. If you drive and generate energy, it is a variable. Want to eliminate as many of those as possible.
  18. TravisBe
    22
    CA
    I turned it on and the engine came on for about 20 seconds then went silent. I turned the a/c on and within 5 seconds the engine and the radiator fans came on. I let the a/c run for about 30 seconds then turned the a/c off. It immediately went silent again. I'm not sure if I'm doing this test correctly.
  19. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Force charge the battery to full, then drain it and see how long it takes.
  20. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    My 2009 used to make that same sound.
    It was the coolant control valve.
