Loud Noise?
Discussion in 'Gen 2 Prius Technical Discussion' started by Rockin Prius, Mar 11, 2012.
  1. Rockin Prius
    Rockin Prius New Member
    61
    NYS
    I have a 2008 Prius 2
    26000 miles
    When I went to park the car...and before I shut it off...the motor... was not running at this point.
    I heard a loud rumble ...kinda like a .... tap tap tap tap tap tap tap tap tap ... constant sound, but way louder than normal
    I then turned it off and it did it again for a few seconds?
    I know there is a pump that runs for a few seconds during the time which I describe above...but this was much louder and a different noise?
    Any ideas?
    Thanks
  2. justjeff
    justjeff Junior Member
    55
    Colorado
    I have what sounds like the same issue going on too. I hope someone responds to this. I am unsure what it is.
  3. cnschult
    cnschult Active Member
    772
    96
    Michigan
    if the car was throwing a code wouldn't a warning light/triangle come on?
