Loud Noisy Brake Pedal on new car?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by mytiels2001, Sep 1, 2015.
  1. mytiels2001
    mytiels2001 New Member
    Chicago
    2015 Prius c
    I have only had my Prius C for 12 days. It has less than 500 miles on it. Tonight on the way home it started making a loud click when I first hit the brake pedal, and then a loud squeak/ pumping (compressing) air sound when I press it down to break. It's not coming from the tires or wheels. It seems to be the pedal itself. The same loud click would happen after I take my foot off the brake. It's very loud, not subtle at all. Is this normal? I am guessing it is not considering it did not happen until today. I will be disappointed if it is because it is quite annoying. I couldn't turn my music up loud enough to cover it. I checked to make sure it wasn't rubbing against anything on the floor when I got out. I also noticed that my battery is not charging over 50%. I drove 20 miles from work to home, braking frequently in the charge zone, so I assumed this should not be the case. This could be coincidence and I am looking for problems because of the noise. I'd take it straight to the dealer if they weren't 2 hours away. Please help. Has anyone else had this issue?
    49,500
    nope, not normal. back to the dealer you go.:( i think the battery is fine, in the 50% range.
  3. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Ditto.
  4. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    What did the dealer say the problem was...?
  5. bisco
    49,500
    faulty brake parts, covered under warranty. thanks for the advice fella's!:)
