Loud PSSSS sound while Refurbing batt
Discussion in 'Gen 2 Prius Main Forum' started by ddangelo, Feb 15, 2022.
  1. ddangelo
    ddangelo New Member
    denver, co
    So I'm using a hobby charger to refurb a used set of cells.
    I've got a CQ3. 7200mah capacity, 5A charge, 1A discharge, 6v discharge votlage.
    I just started cycling - the batt temps are in the 50/60's F
    One of them just made a loud PSSSSS sound, like pressure was just relieved.
    Is this OK?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,231
    5,934
    Columbia, SC
    Charging at 5 amps into a module caused its pressure release valve to release. Usually this happens on a bad module. Shouldn't happen on a good module.
    If 5a causes it, imagine what 50 or more does on regen. I'd imagine that module is done.
    SFO likes this.
  3. ddangelo
    ddangelo New Member
    denver, co
    yes! was one that I knew was most likely bad. I just changed from 5A to 2A and then set my delta peak to 20mV instead of auto. The 5A spooked me . . . thanks so much!
  4. PriusCamper
    PriusCamper Senior Member
    11,105
    4,520
    Pacific Northwest, USA
    I'm always on the hunt for the tiniest diameter water balloons they sell because they fit over the vent covers of the modules perfectly... That way when a module fails it inflates the balloon and captures the toxic fumes so I don't breathe them. It's also an additional way to identify bad modules before they go bad. This one offers similar results as a thermal camera does because the cells that run hotter than the others are the ones that tend to fail in this way.
