Loud rear flapping noise at 60+ mph
Discussion in 'Gen 2 Prius Main Forum' started by elmofongo, Jul 26, 2011.
  1. elmofongo
    elmofongo Member
    253
    SF, CA
    Howdy,
    I have a 2006 Prius and I've been trying to diagnose a flapping noise that's coming from the rear right side when I'm going above 60 mph approximately. It sounds like a "slapping" noise at about 2 or 3 "slaps" per second.
    First I thought something was stuck in the HV battery cooling fan so I took it apart and cleaned it. It was just dusty. That didn't solve the problem.
    I now suspect the rubber flaps covering the vent on the inside of the bumper (see attached picture). I'm not sure what it's called and I don;t know why is would start flapping now. I just had the car serviced for 120K miles.
    Any suggestions?
    Thanks
    -Adrian
  2. Patrick Wong
    18,200
    6,479
    I suggest you check the right-rear tire and axle to see if something is stuck to the tire or axle; or if the tire has a defect that is causing the noise. Good luck.
