Loud Rumbling and Shaking After Starting Motor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by djfnw, Dec 19, 2011.
  1. djfnw
    djfnw Junior Member
    27
    United States of America
    I have a Prius III 2011. I've had it for 10,000 miles and have had no problems at all. Yesterday, when I started the car, it made a loud rumbling and the engine shook, when it transitioned from the electric motor to the gas engine.
    It did that several times when I restarted and then went away. The problem happened on the transition each time. Electric motor came on perfectly and then ten seconds later it was like an earth quake under the hood. My dad watched the engine and said that it shook really hard. At first he thought it might be a fan belt but then he said it seemed more like water or something may have gotten into the gas tank and it was choking...anyone else had this problem?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome to the club... many have experienced the issue though it has mainly been right at startup (of the gas engine).
    There is a huge thread on the issue.
    You should report this to the dealership so at least it has been documented.
  3. djfnw
    djfnw Junior Member
    27
    Thanks. Yes my noise happens right as the gas engine starts up. When I start my car it is in electric mode for about 10 seconds then it switches to gas and that's when the noise happens. I'm taking it to the dealer today and I'll report it.
  4. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    You're in the Prius v forums.
    Good luck with the issue.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep, I flagged it and it's now been moved.
    In the future, the OP should post in the correct area.
  6. djfnw
    djfnw Junior Member
    27
    Ooops, sorry about that.
  7. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Had you started the car and shut it down just as the gas engine fired up prior to starting the car up where you had the engine shaking event? It didn't have to be immediately prior (like seconds) just on the previous start up, did you power it down as the engine came on?
    In both instances where I've had this happen, it was because I was moving my car a short distance (driveway to the front of the house) and I powered off the car as the gas engine turned on. The next time I powered up the car, the gas engine had that horrible knocking noise.
  8. LCDuncan
    LCDuncan New Member
    Pine Bluff, AR
    2011 Prius with loud rattling motor noise as well as what seems to be the engine shaking. Engine light on as well. Took it to the shop - diagnosis = Misfiring. Replaced spark plugs - problem fixed for a day or two. Had to return to the shop because the problem resurfaced. Same diagnosis of Misfiring - Fuel system cleaned. Problem corrected for about a week. Rattling, shaking and engine light returned. I've been using premium gas thinking I need to burn hotter fuel. HELP!!!
  9. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Avoid the shop. Since plugs were changed, you now know it’s time clean your intake manifold and install a catch can.
    And welcome to the knock club, we’re always taking new members.
    Raytheeagle likes this.
  10. Mendel Leisk
    40,586
    How many miles on it?
    How's the coolant level in the reservoir, stable, or regularly dropping?
    It could be the intake manifold is failing, or "just" EGR clogging.
    About neck-and-neck with death-and-taxes, is: Third Gen Exhaust Gas Recirculation (aka EGR) clog up.
    The smiplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    NutzAboutBolts likes this.
  11. LCDuncan
    LCDuncan New Member
    Pine Bluff, AR
    210k miles on my 2011 Prius - I should probably get rid of it BEFORE I have to replace the $3500 batteries
  12. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Check out " Warranty Enhancement Notification ZF3."
  13. LCDuncan
    LCDuncan New Member
    Pine Bluff, AR
    Yes, I have explored that option. Way, way too expensive and won't cover the batteries
  14. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    ??? That "warranty enhancement" has to do with rough starts caused by sticking EGR valve. Not related to battery.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Any coolant loss?
  16. LCDuncan
    LCDuncan New Member
    Pine Bluff, AR
    Thanks - the mileage for this is 150k and I have 210k - but..................it's a direction to go in. Thanks so much.
  17. Tanyatb
    Tanyatb New Member
    usa
    I've had my Prius for over 6years and this happens almost everytime I shut it off before it goes back into electric mode...just make sure you let your car kick out of gas mode before turning it off and you should be fine.
