Loud Rumbling Noise on Startup…
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sh0, Mar 6, 2025.
  1. Sh0
    Sh0 New Member
    Hello, I’ve got a 2008 Prius with 190k miles on it that recently started making a loud rumbling noise when I start it up. At first I thought it might be a loose screw causing the cat shield to rattle against the frame on the lower gears but the rumbling stops after a couple of minutes and doesn’t come back until I start it up the next time. Does anyone have an explanation for this? I’ve attached a link to YouTube with a video of the sound.
  2. saneesh8
    saneesh8 Member
    133
    27
    Allen, TX
    No codes? Coils and spark plugs good? Is the engine vibrating too much?
  3. Sh0
    Sh0 New Member
    No codes other than oil change and tire pressure. I’ll have to check the spark plugs, could it really cause that much noise? The engine does not vibrate at all however…
  4. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    Could be a misfire that your ECU hasn't been able to isolate yet - that's why there's no CEL.
    IMHO; get someone who knows what they're doing to look at it.
    Good Luck....
