Lousy mpg over 100k miles 2010 Prius
Discussion in 'Gen 3 Prius Fuel Economy' started by mikeflores2000, Oct 2, 2020.
Tags:
  1. mikeflores2000
    mikeflores2000 Junior Member
    49
    23
    Merced, CA
    I purchased new a 2010 Prius 3rd gen when
    Mpg was 50.
    Gas consumption terrible after odometer reaches 100k miles. Have you experienced same fuel efficiency drop?
    2020
    08-24 176927 30 mpg 8 gallons Costco
    08-12 176684 29 mpg 8.3 gallons Costco
    07-30 176445 35 mpg 7.3 gallons Costco
    07-21 176187 6.3 gallons mpg 27 Costco
    07-09 176018 8.2 gallons mpg 32 Sinclair
    07-01 175755 4.5 gallons mpg 29 Loves
    06-25 175625 44? MPG 6.23 gallons Costco
    06-16 175510 49 MPG
    06-12-2020 175353 47 MPG
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Not yet. Last week's tank was 67.1 mpg @ 157,000 miles. Depends on driver's driving style, distance per drive & maintenance.
    IMG_3111.JPG miller cat
    SFO likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    WOW! Something sure went sideways back there in late June. Dragging brakes? Failing traction battery? New tires not LRR? Lots of other possible causes.
    SFO likes this.
  4. mikeflores2000
    49
    23
    Merced, CA
    Good catch jerrymildred. Traction battery replaced June 11, 2020 and mpg went from bad to worse.
    My 2010 Prius was purchased new and mpg was near 50 mpg. Since odometer passed 100k mpg nosedived made worse with a refurbished traction hybrid battery installed. Attaching photos. Refueling today at Merced’s newest Arco gas station with new storage tanks and clean premium gas. Could be fuel injectors damaged or bad transmission.
  5. bisco
    49,437
    refurbished says it all. why not get a new one?
    mikey_t, SFO, kenoarto and 2 others like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Looks like a local company to me :cool:.
    A decent fee for the swap too:(.
    Doesn't appear that longevity will be on the OP's side:whistle:.
  7. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    "AVG. 14 MPH": How many of your trips are less than 5 miles? Did you have a life event at the end of June (retirement, change jobs, move) that changed your commute? If nothing changed, I would suspect the refurbished battery first.
    kenoarto likes this.
  8. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    I have a 2010 IV with 100,000 miles but with a very different experience. My mileage has slowly decreased over time but is still overall in the 40's. The vehicle runs perfectly. No indication of a failing battery.
    I'd suggest getting an OBDII bluetooth enabled adapter that plugs into the diagnostic port under the dash. Then run the Dr. Prius App to assess the health of the refurbished battery. If that battery is under a warranty, you may have a case to have it replaced.
    kenoarto and jerrymildred like this.
  9. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    I suspect that the thermostat has failed. It probably stuck open and ICE not achieving full operating temperature. Or failing 12v battery. Check the 12 v health and see what it’s doing voltage wise after setting overnight. I only drive my high mile 2010 5-6 minutes per trip and I’m still in the mid to high 40’s for MPG. Mine were down to the high 30’s a couple months ago, but replaced thermostat and they recovered to their current level.
  10. badbrakes1998
    badbrakes1998 New Member
    Delaware, Ohio
    I drive a 2010 with 150k miles and get about 38-42MPG depending on the trip. I had a caliper stuck closed and changing it increased MPG.
    mikey_t and SFO like this.
  11. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Given the mileage, doubtful. Though in the moment you could spill and fill the ATF-WS, which should prolong the agony :confused:
    If we all need another WAG, let's assume that the 'rebuilder' (used loosely) installed the "degraded replacement pack" after disconnecting the 12v source, then failed to clean the MAF o_O
    Coming from the gen2, this often happens for me. Though it could just be my continued desire for dyslexia as well :cool:
    Raytheeagle and Aaron Vitolins like this.
  12. bret kraupie
    bret kraupie New Member
    If you look at your screen shot to the right your ave. 38 mpg
  13. jerrymildred
    11,508
    14,110
    Tampa, FL
    Oops. You might want to look again. He's averaging 67.1 mpg and 38 mph.
  14. Mendel Leisk
    38,706
    Just cherry-picking: I doubt that’ll improve mpg, just costs more.
    mikey_t likes this.
  15. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    212
    109
    Canmore, Alberta, Canada
    Seems like checking to make sure the 12v battery is still good (or just replacing outright if it is 5 years old or older) would be first thing I would do.
    Then I'd follow up on the HV battery.
    If both the batteries are good I'd start looking at other possible causes.
