Loving 2022 prius prime, but expected higher mpg
Discussion in 'Prime Fuel Economy & EV Range' started by Emmy2022, Feb 7, 2023.
  1. Emmy2022
    Emmy2022 New Member
    Austin TX
    2022 Prius Prime
    Hi all! I just bought my first ever prius - a 2022 Prius Prime XLE. I upgraded from a base model honda fit, so I’m loving my new car. I’m getting about 30miles of EV which is better than expected, BUT I was expecting higher mpg when in HV mode.
    I live in Austin TX, but I bought the car in my home town 500 miles away. On my way home - all highway going up to 85mph - I averaged 45 mpg. I understand that high speeds will hurt the fuel economy, but I’m sometimes getting about 45mpg on shorter (5-10 mile), slower (<55mph), no AC trips around town as well.
    I’m seeing high mpg trips too - around 65mpg - especially in slow moving highway traffic and with careful driving. I was expecting to be able to reliably get 50-55mpg without really trying (that is, driving like I normally do - not aggressively by any means, but keeping with traffic). I get that to max out the fuel economy I’ll need to drive more carefully and conservatively, but I didn’t think I’d need to change my driving to reach that 50-55mpg range.
    For my current tank of gas, I’m averaging 63mpg but that includes charging the car several times.
    Thoughts? Is it normal to see <50mpg if not driving conservatively? My next step is to go all HV for a tank of gas and calculate the fuel economy on my own. So far all the stats are according to the car.
  2. vvillovv
    vvillovv Senior Member
    4,332
    1,515
    NY
    As normal as normal is these days at 85 and keeping up with traffic.
    TGrracie and Emmy2022 like this.
  3. Leadfoot J. McCoalroller
    8,149
    7,652
    Pennsylvania
    2018 Prius c
    If you're scoring 45mpg while spending significant time at 85mph, you're kicking butt.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Yes, this would be normal MPG for HV operation per your statement. Plus, you will get lower MPG in colder weather since the ICE (gasoline) is used for heating the cabin. Your MPG will increase in warmer temps and with conservative driving.
    McCarthy and Emmy2022 like this.
  5. Emmy2022
    Emmy2022 New Member
    Austin TX
    2022 Prius Prime
    Thanks for the input everyone! That makes me feel so much better.
    If this is normal, I’m happy with it. Like I said, I’m really enjoying the car - it’s much more fuel efficient and stylish than my last car and that’s what I wanted.
    My last car started having a lot of problems out of blue, and I spent the last few months of driving it just waiting for the other shoe to drop. I think that made me hyper vigilant of any issues with the new car.
    Anyways - thanks again! Happy driving, y’all!
  6. bisco
    52,395
    try some conservative longer trips just to be sure there's nothing wrong. the epa tests are fairly conservative
    Emmy2022 likes this.
  7. Gokhan
    Gokhan Senior Member
    6,545
    2,613
    Paramount CA
    You are not going to get good fuel economy at 85 mph obviously, as the air drag increases with the square of the speed.
    You should get around the EPA highway value at 65 mph.
    You should get around 70 mpg at 55 mph.
    Try setting the A/C at 68 ℉ in the winter and at 78 ℉ in the summer. That will vastly improve the fuel economy.
  8. Gokhan
    6,545
    2,613
    Paramount CA
    A higher tire pressure also helps. I use about 41/40 psi front/rear.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    If you are doing 500miles at 85mph, 45mpg is very good. Anything faster than 72mph, there is no EV, unless you are in a very long downhill.
  10. nicoj36
    nicoj36 Active Member
    518
    162
    Try a bottle of chevron fuel cleaner.
  11. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    I bought my 22 Prime last March, and have taken three 2600 mile R/T highway trips so far. In the warmer months I got 49 MPG (gas only) running 75-80 avg (GPS - the speedo is 2% high and inflates miles and MPG). Last trip in cold weather was around 44 MPG, but I was going a bit faster most of the way. My old '13 Prius only got about 38 MPG under best conditions. Oh, that last trip was with winter tires, too.
    vvillovv likes this.
  12. Mendel Leisk
    41,909
    Calculating your mpg is the best way to see your accurate mpg; Toyota has a propensity to exaggerate the dash displayed mpg (by a reliable ~7% on 3rd gen). It's good to track your tanks, see what helps/hinders mpg. Some tactics that will help:
    1. Keep the speed down; be the slow-and-steady right laner.
    2. Maintain a good following distance in traffic. This often allows you to avoid braking in minor slowdowns, which robs your momentum.
    3. Plan your trips, consolidate errands. Avoid short, impulse drives, especially if something's walking distance.
    4. Minimize AC use.
    5. NEVER sit parked with the car on. If you have to wait in the car, just shut it off, crack the windows.
    Set your display up to show the Hybrid System Indicator (HSI). This is 3rd gen, and a little simplistic, but explains the basics:
    #12 Mendel Leisk, Feb 15, 2023
    McCarthy likes this.
  13. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    In comparison testing. Any PHV or even HEV that can score 48 MPG or better will be equal to an all electric vehicle. If driven the same and at the same speeds/acceleration. This is in terms of charging costs or for an HEV refueling costs.
    So if you drive a bit normal 65 MPH to 70MPH, you will be equal or less than the cost of an EV.
    Heck the standard Prius is often better performing than the PHEV if driven at speed. I regularly obtained 70 MPG while doing 70 MPH in the standard Prius. But I get worse in the Prime.
    This is likely because the Prine is heavier by about 300 lbs.
  14. captqc
    captqc Member
    70
    43
    Oregon
    2022 Prius Prime
    Really disappointed that I can’t hit 1000! :whistle::D
    Danno5060 likes this.
  15. McCarthy
    McCarthy Junior Member
    94
    85
    MPG is not so much about the car and tech, its mainly about weight, drag, drafting and maintaining momentum.
    I could pull over 70 MPG out of my old 2011 VW Jetta Wagon with a 4 banger turbo diesel and no hybrid / EV tech. The record is 84 MPG in a VW Passat with the same engine.
    At constant speed, try to draft behind larger vehicles. You don't have to tailgate but 3 car lengths behind a larger truck will do wonders. Following a truck at 65 mph is the equivalent of going 45 to 50 without any drafting.
    Always look 2 blocks / lights a head. Time your arrival at every light. When you see green, make sure you will roll through in time by speeding up. When you see red from afar, coast and make sure you don't have to come to a complete stop.
    Accelerate with a raw egg under the pedal, unless you are going to piss off others.
    #15 McCarthy, Mar 29, 2023
    Tightwad77 and Danno5060 like this.
  16. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    I think the telling statement is “keeping up with traffic”. Most drivers seem to accelerate fairly aggressively and not maintain steady speeds. Do you use the cruise control? My 2018 averages in the low 50s at 65-70 with cruise on.
  17. Tom Redinger
    Tom Redinger New Member
    asheville, NC
    2018 Prius Prime
    Speed is definitely an important factor with mpg in HV mode and more important in EV mode by my experience with my 2018 Prius Advanced. In HV mode I drive the speed limit, OR 65 whichever is less, and average 60 to 65 mpg depending on traffic, temperature, weather in general (rain). I did a test over 60 miles of flat interstate where I drove the speed limit of 70 and car-reported gas mileage dropped to 57 mpg. I'm able to use about 96% EV mode only in my local driving around Asheville, NC and normally get 5 to 6 miles per kWh--much better than the 4 miles per kWh suggested by EPA. (I have a PN-2000 watt meter I use every time I home charge to get ACTUAL kWh usage.) I stay off the "fast" highways in favor of lower speed rural roads so that normal around-town driving is usually 35 to 45 mph or less which I'm sure is a big part of why I get 5 to 6 miles per kWh rather than less. (I'm retired so a few minutes more to destination doesn't matter.) Cold weather--20s--can bring that figure down under 5 in spite of low speeds but that doesn't happen that often in Asheville.
