Low 12V battery apply brake ...
Discussion in 'Gen 4 Prius Main Forum' started by shadow4478, Mar 7, 2021.
  1. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    Does anyone know is this is a sign of new battery needed ? I haven’t check the voltage yet, just walked away ans started up 10 min later...
    it’s a 2017 Prius with just under 70000km
    It’s super cold outside
    see image with error message
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    What ELSE would you think it is a sign of ??
    Loose or corroded cables maybe.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    I'd get it checked - rather than replace. It's a proper flooded battery, and should last longer than that. Mine is almost 5yrs old and going fine - but it is HOTtish outside (32°C).
  4. ChapmanF
    16,127
    I would think it might be a sign of a 12 volt battery needing a charge.
    fuzzy1 likes this.
  5. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    Just looking to see if anyone dealt with this and making sure there’s not an obvious solution.
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,000
    498
    Tucson, AZ
    2021 Prius
    You might want to do the normal battery maintenance activities like checking for post corrosion and loosen up each clamp, give it a twist, and cinch it back down. The US market battery has cell inspection caps you can remove and check for electrolyte level, but depending on how super cold it is there you probably don't want to add any distilled water just yet. Funny, your included pic shows an outside air temperature of 74 F. Lastly, having the battery load tested somewhere will tell you if it might require replacement or not.
