Low Battery voltage positive Side Code
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Tcman231, Sep 9, 2021.
  1. Tcman231
    Tcman231 Junior Member
    Michigan
    2018 Prius
    Four Touring
    Hello Everyone, I recently purchased a 2018 Prius 4 Touring 30,000 miles on the vehicle.
    I scanned the Prius with a scanner and it gave me a low battery voltage positive side code C1241 ABS Code
    Now, Unrelated/Related , I had to jumpstart the car 2 times in the last few weeks. the other day i went to accelerate from a stand still car did nothing for a few tries "no electric motor" sound then decided to go
    now this tell me i need a new battery...but why would it mention "abs" with no abs light also no other warning lights or engine light on? again I'm thinking new battery but a new Prius owner like I said.
    Thank you in advance
  2. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    Low battery code and jump starting? Battery related, of course. Replace/recondition your 12V battery and keep it on a trickle charger from now on.
    jerrymildred likes this.
  3. ChapmanF
    17,347
    C1241 is a code detected by the brake/skid ECU, where it sees that the voltage arriving at its own power supply terminal is lower than it should be.
    It doesn't always have to mean a problem with the 12 volt battery, of course. Because the voltage is detected low at the brake ECU, the problem could in theory be anywhere in the wiring or connectors leading to that ECU. That's why the code is specific, to make sure a diagnostician has enough info to consider all the possible causes.
    On the other hand, in cases where you know your 12 volt battery has been low enough to require multiple jump starts, there's no need to wander too far down the maze of other possible causes for the C1241.
    JohnPrius3005 likes this.
  4. Tcman231
    Michigan
    2018 Prius
    Four Touring
    I knew they were related of course but didn't understand the abs part I guess ha ha I'm still learning about this whole deal here if were a regular gasoline engine .. you know check the alternator and get a battery if it was charging lol thank you much !
    #4 Tcman231, Sep 10, 2021
  5. CooCooCaChoo
    CooCooCaChoo Senior Member
    953
    533
    Cow-lee-fornia
    2023 Prius
    Dead or dying 12v battery causes a lot of weird problems. Because you live in Michigan, I would replace it before it starts snowing. The cold weather reduces the capacity of the battery.
    Tcman231 likes this.
  6. Tcman231
    Michigan
    2018 Prius
    Four Touring
    thank you! yes definitely what I was thinking as well...still learning something new every day about the Prius lol
    #6 Tcman231, Sep 10, 2021
  7. Mendel Leisk
    40,584
    For starters check it’s voltage, with a volt meter, car off.
  8. Tcman231
    Michigan
    2018 Prius
    Four Touring
    just finally did that … 11 volts
  9. ChapmanF
    17,347
    Wouldn't hurt to put a charger on that animal.
