Low Beam and Both FOBS quit working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pabulluck, Mar 29, 2011.
  1. pabulluck
    pabulluck New Member
    Warrensburg, MO
    I have a problem with my 2007 Prius. The low beam and both FOBS for the car quit working at the same time. It worked the previous day as always, then the next morning, the car would not automatically unlock and had to use the FOB mechanical key for entry. Then I noticed that the headlights (LOW)would not turn on, but the high beams worked fine. Has anyone else had this same problem. just an FYI I have changed the headlights on this car at least 3 times in the past 4 years. Any help would be greatly appreciated.
    Thanks,
    John B.
  2. pbbcpm6
    pbbcpm6 Junior Member
    San Lenadro
    I wish I have a answer for you but I'm very curious what the repair will be. Please let me know the fix. Good Luck
  3. gbarry
    gbarry Junior Member
    79
    16
    S. California
    Maybe there's a fuse in common with those?
  4. Patrick Wong
    18,200
    6,472
    1. Find the button which controls the Smart system, located on the instrument panel at the lower left below the steering wheel column, and press that to see if the system was turned off. If that doesn't help, replace the fob batteries to rule that out as a cause of the problem.
    2. Regarding the headlight low beams not working, the headlight low/high beam relay may be stuck or else the headlight switch is broken. The relay lives in the main relay/fuse box near the inverter. If you have an ohmmeter and a source of 12VDC power then remove and test the relay to see if it works.
  5. pabulluck
    Warrensburg, MO
    FYI I was able to get the FOB working again by replacing the battery!!!! I almost had a coronary when it unlocked the door. I really had my doubts about it working. The low beam lights are still a no-go. Total cost so far to repair is $6.93. Hopefully it will be as inexpensive to fix the lights as the FOB was. I am keeping my fingers and toes crossed! Thanks to all for your quick replies.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    FYI, if you paid $6.93 for a single CR2032 battery, you got ripped off.
    They're $1.79 + tax at Fry's Electronics around here. I was at my local O'Reilly auto parts today and saw a pack of 2 for (IIRC) $5, which is a bit high but not unreasonable.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    They are 28 cents apiece from Digikey, although it doesn't make sense to order a single battery.
    Tom
  8. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Wow! Thanks!
    Yeah, one would have to order a couple to make it worthwhile... Cheapest shipping for me is $2.41 for 8 ounces.
