Low beam headlights sometimes won't turn on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by coquipr79, Oct 26, 2018.
  1. coquipr79
    coquipr79 New Member
    VIrginia
    I have a 2010 Prius II without HID headlights. Recently I've been having an issue that the low beams wont turn on at times. Sometimes they will and other times it wont. Today they turn on but are dim. Any idea what the problem could be?
  2. ChapmanF
    15,662
    Check the connectors at the bulbs? Then the one from harness to harness, behind the bumper cover, forward of the left front wheel well? If not solved, get a meter and go from there?
    -Chap
    Raytheeagle likes this.
  3. fuzzy1
    10,172
    Failing headlight relay?
