Low electric mileage
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mwhelm, May 3, 2019.
  1. mwhelm
    mwhelm Junior Member
    My electric mileage seems to have abruptly plummeted. Dash shows 13.2-13.8. Charges on
    L2 (or L1) no problems.
    I would get roughly this mileage out of it, but I didn't test closely (however I am mindful of the
    charging rates & usage because we have a new ETOU electric billing here & I sometimes adjust
    the charging amount to cover small trips only).
    Noticed a few days ago that I wasn't seeing that all & the change seemed abrupt- distances that are about half that estimate, would use up the entire charge. Checking more closely with an odometer last night, a 4 mi local trip consumed the entire charge well before the trip was complete.
    2015 PIP with about 75k on it. Tire inflation is right on the recs.
    Any ideas/recommendations?
    52,436
    to be clear: you're saying that a full charge used to go more than 13 miles, and now you can't even get 4 miles?
    if that's the case, you may have a serious issue. do you have a way of measuring charge amount in kWh?
    is it still reporting 13+ miles on a full charge?
    does it take the same amount of time to charge?
    any decrease in mpg's?
  3. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Yeah, something does sound fishy about that. I presume you are this is a consistent and reproduce-able situation now, that the display range depletes much faster than actual range? If so, it should be pretty easy for a shop to hook up and diagnose if there is a problem with the battery? Assuming it is a battery issue, I believe that should be covered under the battery warranty, which I think is 100k miles? (I know it is 160k KM in Canada).
    As I side note, I don’t think I have ever seen >13 miles (~21km) on my ‘14, I usually have 16-18km (10-11 mi, and usually closer to 10) on a charge, and it has been this way since I got it at 2 years old. Now I am wondering if there is something wrong with my battery, LOL. :confused:
  4. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    In my experience, seized rear brake caliper slide pins led to a reduction in range, though it was only somewhere around 1 mile for me. They're worth checking out, especially if you're in an area where roads get salted in winter.
  5. mwhelm
    I think "13.2-13.8" miles actually resulted in about 12-12.5 miles, but I wasn't looking as closely. I just know the
    rough mileage between home and a couple of sites and what I would expect. I have been mindful of ETOU costs
    and trying to charge only what I need for short trips during the ETOU peak window.
    Measuring charge amounts - my charging station has history. The full charge time of 1.15 hrs and ~2.4 kwh seems to be
    constant.
    The full charge estimated distance has fallen from 13.5-13.8 to 11.5
    Gas mileage seems unaffected. I'm not watching it closely so it's just my feeling, but I have the same week-on week pattern
    and about the same fill up rate (1x / 9 da)
  6. mwhelm
    We should have a reasonable warranty here, but it's going to cost me to test it. Negotiating for this is like
    negotiating for a specialist at the HMO - I have to wait for the battery guy to come back from vacation.
  7. bisco
    52,436
    where are you, and what are you driving?
    i'm still not clear, but again, if you're only getting 4-6 actual miles on a full battery, something is definitely wrong.
    in the united states, it is not covered under warranty
