Low engine oil pressure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2012PriusII, Jan 28, 2020.
  1. 2012PriusII
    2012PriusII Junior Member
    2012 Prius II 177K miles
    Need guidance of look into repair, replace, and insights/recommendations for what to do.
    I am considering taking it to be assessed but am concerned about driving.
    It has only required routine maintenance to this point. I was hoping to get more miles from it and like it more the older it gets (current situation excluded).
    Some info:
    - Original Owner
    - 177K miles
    - Regularly maintained, no ERG cleaning (just learned about that here)
    - A few months ago a dealership let me know the oil was low and dirty, after it had been changed about 2 weeks prior at a different dealership - I saw the oil and level.
    - For a couple of months the car would sometimes beep when I made a hard right turn - no lights on the dash or anything
    - System maintenance light came on, wife called dealership and they said it's fine, no maintenance needed
    - Finally, the beep came on and for about a second (literally) there was a flash on the dash that said low engine oil pressure
    - Put in about 3-4 quarts of oil and drove for a couple of days, no visible oil leaks
    - Started one day and there was loud engine knocking, wife said it had previously done that. Has reduced/gone away.
    - Have only moved car into garage since then
    Codes (used blue driver):
    - C1241 ABS, low or high poser supply voltage
    - B1442 AC, Air inlet damper control servo motor
    - B1585 Navigation system (don't have navi on the car), current/history usb device malfunction
    - P148F Engine, Current/history engine coolant pump over revolution
    - B2312 RR door motor code, current/history, check report for description (nothing)
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    The Blue Driver software is pretty extensive. It can describe the codes in detail and suggest the top solutions that mechanics have found. Just as a stab in the dark, I'd say the engine is running hot and causing the coolant pump to over-rev. Being down by 3-4 quarts will undoubtedly do that. The seriousness of the problem depends on how quickly the car drank that many quarts. 2 months/2,000 miles? That would be kinda bad. 6 months/6,000 miles? Not so bad. You definitely don't want to let it run so low on oil again. There's an even chance you already need a new head gasket. Unfortunately, no code says, "Replace head gasket."
    scona likes this.
  3. fuzzy1
    10,705
    Oil low and dirty in just 2 weeks -- did the first dealership actually do an oil change? It seems more likely that they somehow failed to do so.
    Leaks are just one manner of losing oil, there are others. That is why regular oil level checks are required in between oil changes. When it gets down 3-4 quarts, you have gone far too long. See this recent thread for more details:
    What's with exclamation mark sign? | PriusChat
    This is just a special hidden trip odometer that is supposed to be manually reset at each maintenance. Technicians sometimes forget to do this. The Owner's Manual tells you how to do it. But whenever it does light up, do check when the previous service was done, to see if it is actually time for more.
    I have no feedback on the various trouble codes, hopefully others will.
    Mendel Leisk and jerrymildred like this.
  4. 2012PriusII
    Thanks, I appreciate the thoughts and insight.
    Thanks for the good information. It seems like the one dealership did not change the oil.
    #4 2012PriusII, Jan 28, 2020
  5. fuzzy1
    10,705
    This is one reason I always check the oil myself shortly after fetching the car. This also tells me the starting level, which is almost never right on the dot.
    If I was more proactive, I'd check right at the shop every time. It was such a time that I first discovered a nice wrench left atop the engine. Only after returning it did I also discover the oil cap was left off, sitting beside the filler hole. At that point, I felt I should have just kept their wrench. Regardless, I never did any more business with that shop (a regular stealership, back before the proliferation of quick change places, and oddly still in business).
    anonymous likes this.
  6. Mendel Leisk
    42,331
    I drain and fill the oil myself, and put in the spec 4.2 liters (4.4 quarts). Carefully measured with a 5 liter pitcher/graduate. And yeah I know about capillary effect, how fluids kinda curve up at the container wall.
    Checking a day or two later, it's invariably about 1/4" below the top mark. I leave it alone, and so far it's never budged from there till the next oil change.
    fuzzy1 likes this.
  7. anonymous
    anonymous Member
    177
    104
    US
    Did you not ever check the oil level during this time?
    The gen III Prii are notorious for oil consumption as they age (at least in my experience and from what I heard). If you drive a lot (especially with severe conditions like mountain roads) then it is relatively "normal" for the oil level to drop below the low mark every two weeks. You need to check the oil level regularly, like every weekend or 500 miles, and add oil as necessary to keep the level between the two marks (preferrably closer to the top one, so it lasts longer, but try not to overfill either).
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I check oil every other day and no burning yet, knock on wood. It’s near 150,000 miles w/100 mi daily commute & 13,000 mi oci. Let engine temp go up gradually then drive like a maniac is my best advice to minimize head gasket destruction.
  9. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
    Coolant pump over revolution:
    When the pump impeller shears from the drive shaft, the pump motor is now unloaded and goes into free spin at high rpm and stops pumping any coolant. Replacements are available to be found, maybe amayama.com.
    iPad ?
    mjoo likes this.
  10. Mendel Leisk
    42,331
    IIRC Amayama wasn't too competitive for water pump, but do comparison shop. It is a good source for Canucks, and sometimes their prices are very good.
