Low humming noise out of prime sitting in my garage (not charging)
Discussion in 'Prime Technical Discussion' started by ct prius dedicated, Nov 28, 2022.
  1. ct prius dedicated
    71
    37
    2022 Prius Prime
    So the car is not charging and is just sitting in the garage. I drove it 5 hrs ago and it still has some charge left . Is this normal?
    49,489
    yes, just an evap check. scared the dickens out of me the first time i was in the garage when it started
    gmenchen likes this.
  3. ChapmanF
    15,614
    That's a frequently-asked question around here. You can read about it on page 8 of your owners' manual:
    For the morbidly curious, another of the many threads where it's been discussed has a diagram of exactly what the car is doing in that test. This picture is from the Gen 3 repair manual, but the Prime details are probably not a whole lot different.
    You can see you might hear that pump running for as long as 22 minutes and change, depending on how long step C goes.
    gmenchen and road2cycle like this.
  4. ct prius dedicated
    71
    37
    2022 Prius Prime
    Thanks ...that's a relief!
