Low inter city mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by Manhal K Alrashdan, Sep 24, 2015.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    I'm a new prius Gen 3 owner. From what I read so far, I should expect higher Mpg when driving inside the city slow traffic than when driving on the highway. But what happens to me is the opposite. I usually get 55-60mpg on the highway using mostly cruise control, and only 35-40 in city busy traffic. My prius 2010 has 135k on her. Any explanation?
    51,140
    that sounds about right, actually. it depends on the type of city driving, but heavy congestion will kill your mpg's.
  3. bwilson4web
    16,010
    There are some threshold speeds:
    • 42-46 mph (67-73 km/h) - this is the boundary between hybrid mode when the engine can turn off and above which the engine has to run all the time. When possible, try to be below 42 mph or 67 km/h.
    Braking early and longer tends to improve energy capture by the traction battery. Braking harder and shorter is sometimes unavoidable but when approaching a traffic light, stop sign, or other traffic slow-downs, begin early so you can save as much energy as possible.
    Warm-up for the first 1-2 miles (1.5-3.0 km) uses the most amount of fuel on any short trip. As much as possible, try to take it slow and even consider shifting into "N" to coast during this time. The transmission is entirely electronic so shifting between "D" and "N" is safe especially if you have experience with a manual transmission car.
    Using "ECO" mode is reported to moderate the air conditioner. I don't have any data but reports are it will still cool the car but not as aggressively.
    Taxi or delivery use?
    GOOD LUCK!
    Manhal K Alrashdan likes this.
  4. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    We don't know your situation, but I'd guess excessive braking, short trips, congested traffic, or some combination. Also, what Bob said.
  5. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    If you have a series of errands, go to the longest one first and work your way back home. That allows the car to fully warm up and stay warm for all your errands. Warmed up car equals best gas mileage.
  6. bisco
    51,140
    have you studied pulse and glide? of course, a/c can eat up mpg's.
  7. Anas Almustafa
    74
    28
    Arbela, Irbid, Jordan
    I drive in jordan with a prius too and i see almost the same numbers for in city driving 35 to 40 MPG
    It seems when you're stuck in traffic and you have used up all your battery the engine will come one and will keep running until the battery is charged to a certain point usually more than 30% or so which then is used up and the engine turns on again and starts charging.
    ((( The Engine becomes the - only source of charging - the battery- slow speeds - very brief short braking - which kills MPG )))
  8. Mendel Leisk
    40,574
    Also, Air Conditioning will tend to be less efficient in low speed city driving: there's less air flow coming through the radiator. Coupled with battery running down, then engine running constantly, as mentioned above.
  9. bwilson4web
    16,010
    High battery temperatures can also trigger engine running. I first saw it this summer.
    Can you get instrumentation to measure traction battery temps?
    #9 bwilson4web, Sep 27, 2015
  10. Manhal K Alrashdan
    81
    16
    jordan
    Thank you Bob,is it safe to shift to N while on the move, in manual cars, you can disengage the gear while descending down hill, to save gas. But is this feasible in the prius.
  11. Manhal K Alrashdan
    81
    16
    jordan
    Actually, we have 'nt any problem of warming up here in Jordan, as we have warm weather most of the year.
  12. Manhal K Alrashdan
    81
    16
    jordan
    Yes, I have, but you can't use pulse and glide on inner city bumper to bumper traffic.
  13. Manhal K Alrashdan
    81
    16
    jordan
    No, I can't. How can I do that?
    However, I doubt it's the case with me as my errands are short;less than an hour, and I usually run the AC which improve the cooling of the hybrid battery through the vent in the back seat.
  14. Manhal K Alrashdan
    81
    16
    jordan
    Thank you Anas, it's good to have fellow Jordanian in the forum. I,m also from Irbid.
    Anas Almustafa likes this.
  15. bwilson4web
    16,010
    1. MiniVCI - about $30 (USA) but requires a Windows XP laptop. The advantage is the Techstream software has all of the Prius known metrics. But it is not easy to run in the car because of the laptop and if you don't have one, it becomes an extra expense.
    2. Scangauge II - about $150 (USA) which runs by itself. There are XGAUGEs that are about as difficult to program as sending an SMS message on an old flip-top phone. It can display four metrics at a time so it is a good driving tool but it has no data recording capability.
    3. Android/iPhone apps - about $50-100 (USA) depending upon OBD interface. Derived from street-racer software, some hold a lot of promise and the ability to record metrics. I tried one but was not terribly impressed but it was a borrowed Android, software, and interface.
    Personally I like the MiniVCI because of the wide range of metrics and ability to record data. A small laptop can slip under the drivers seat. Not a 'driving tool', it is also a diagnostic tool if anything goes wrong.
    I drive with a Scanguage II and find it also meets 90% of my data needs. The lack of data recording is a problem since even if you use a camera, there is a data entry issue.
    I leave the Android/iPhone apps to others who are more committed to those technologies.
