Low mileage after a lot of idling with ac on all the time
Discussion in 'Prius c Main Forum' started by Aqua2014owner, Jun 15, 2018.
  1. Aqua2014owner
    Aqua2014owner New Member
    29
    Karachi Pakistan
    2014 Aqua
    Last month in very hot weather I was also doing a lot of idling with ac on all the time on short trips (with the shift lever in Park position) and I was getting very low mileage for the trip like 5-8 Km/L, and an over all drop of mileage to around 10-11 Km/Liter, but now with weather less hot my car is still giving low mileage like 12-14 km/Liter even on longer trips. My air vent for Hybrid battery below rear seat is clean & I recently changed oil & air filters and my car was giving good mileage after that.
    Any suggestion from other Prius C owners
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Any lights showing on the dash, and MFD?
    You didn't state the miles on her. Probably you need to do some tune-up on the engine, such as spark plugs replacements and all that.
    What kind of tires and tire pressures do you maintain on your car? All that have impacts on your MPG.
    Finally, might be that your HV battery is already showing some signs of weakness. Definitely, in hot climates, for instance in Africa and the Middle East, batteries deteriorate more.
    Dxta
  3. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    Please read below
  4. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    It's 2014 Aqua (Japanese domestic model Prius C) 43000 Km ( about 27000 miles) No warning lights, tire pressure 32 psi, tires according to Toyota specs
  5. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    If there aren't codes , and all that, your car might be OK. Could just be suffering from the impacts hit temperatures is having on the battery pack.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    First, be sure that you are actually looking at a mileage number that is reset for each trip......or manually reset it yourself.
    IF.....you are looking at a running average, then a "bad" spell will drag down the average, theoretically forever.
    Starship16 likes this.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Check that the vent in the back seat isn't blocked. If it's not, it could just be that the temperature is extremely hot. Even without running the AC and rolling windows down, the car still doesn't like it when it's above ~90 from my experience.
    dubit and Starship16 like this.
  8. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    12-14 km/Liter is definitely too low for long trips, unless you are driving extremely fast. And even then I can't imagine a C giving mileage that low.
    You said the hybrid battery fan vent was clean and unblocked, but I would check the fan itself. Two clips hold the panel on. Here's a video that shows how to do it, with a pretty dramatic shot of how dirty the fan's mesh filter inside can get.
    Also, I would up the tire pressure to at least 36. Many Prius owners use 40 and higher, but I find the the small mileage gain not worth the loss of ride comfort. I average 50-60 mpg at 36 psi. 32 is very low.
  9. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    Hi guys
    I am back after a while, and i have some interesting observations to share, after the few days when I was driving my car only for short distances with lot of waiting in idling and AC running, I was having a very low mileage for one or two trips of about 20 Kms each, then with regular driving the average sprang back to normal ! On one trip with little traffic on the road she averaged 39 Km/L that is 91.7 MPG! that was my best ever mileage, but one thing I could not understand was the reason for low mileage, because a friend of mine slept in his car overnight with engine & AC running in temperature above 34 Celsius and he reported no problem, although he did not bother to check the Km/ Liter reading.
    Now I have some doubts about the accuracy of 'Trip average' reading. I am going to buy an OBD II Bluetooth sensor and try to get more info. any comments?
  10. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    None of this tells us why you think this is wrong... just that one of your trips was good, but another was not. I have an OBD attached to my phone, using Torque and the readings are pretty close.
    I have never personally seen a tank that was off more than 1 mpg from my hand calculation. I attribute that to the car being more knowledgeable about how much gas it is using in the injectors, whereas I have no real idea about how much I am really putting into the tank, since gas pumps aren't super accurate.
    I've had to sleep in my car overnight due to a blizzard while driving thru Kentucky on my way to Minnesota. Kept the car nice and warm ~80 degrees with the seat warmers on for 9 hours. That was the first time I found out that the car goes below zero F. That was my worst tank, but still got 35.77. Was scary seeing other drivers turning their cars off to save gas. I only used 2 blips on the gas gauge for the 9 hours.
  11. sam spade 2
    7,035
    2,788
    2017 Prius c
    It is really very simple.
    When you use fuel with idling with A/C on AND you don't move much, the average goes down.
    But a lot of people don't seem to understand the simple math of an average.
    Miles driven divided by fuel used. If the fuel used goes UP and the miles driven doesn't, your average suffers.
    mohsin, ztanos and Mendel Leisk like this.
  12. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    Sorry, I couldn't understated "car goes below zero F"
  13. Aqua2014owner
    29
    Karachi Pakistan
    2014 Aqua
    couldn't understand "the car goes below zero F", please tell me what you meant
  14. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    The internal thermostat that shows ambient air temperature. It was -5 outside and the temp reading was -5.
