Low mileage, how often oil change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gene4655, Jun 21, 2017.
  1. gene4655
    gene4655 Junior Member
    51
    We have a 2014, wife's car, bought 9/14. Has only 18,100 miles on it. Last oil change 9/16 with 14,500 miles on it. . About to take a 2,500 mile trip. Should I get oil changed, even if only has 3,600 miles on it? Has had no problems at all. What do you think?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    I would change it if I was going to take a long distance trip.
  3. JC91006
    16,482
    8,400
    I would leave it until after your trip, get a little bit of your money's worth on the oil change
  4. Mendel Leisk
    38,735
    Probably no. For sure not immediately before the trip, in case something gets screwed up. Where in the big wide world are you btw, the schedules vary. I'm assuming USA.
  5. NavyLCDR
    NavyLCDR Active Member
    188
    120
    Stanwood, WA
    That depends. Do you know what oil is in it now? The 10,000 mile oil change interval only apples to 0W-20 synthetic oil. If you don't know what oil is in it now, I would change it at no more than 20,000 miles on the odometer with 0W-20 synthetic oil.
    Not only that but...an early oil change never hurt anything other than the wallet for $35 and 1/2 hour of time.
  6. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    This is a personal choice. I would look at clarity of the oil. I would say 12 months change oil, if I felt like it, But I agree with Navy above, if I knew I was going to have a long drain interval. I would use Mobil-1 Extended or something like that, and then I would go maybe 2 years,
  7. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Every 12 months or 10,000 miles ,
    my dealer offers $ 9.95 synthetic oil and filter and 20 checks if the vehicle was purchased from them
