Low miles '03 vs high miles '06
Discussion in 'Gen 2 Prius Main Forum' started by bkebschull, Jan 1, 2011.
  1. bkebschull
    bkebschull New Member
    Castaic, CA
    I'm considering two used Priuses that are each around $8K. One is an '03 (1st gen) with 75K miles and the other is an '06 (2nd gen) with 162K miles.
    1.Without knowing how well either has been cared for, which is likelier to have fewer durability problems?
    2. How much longer could I expect the battery in the '06 to last?
    3. Overall, how significant are the advantages of the 2nd gen over the 1st gen?
    4. Without knowing anything else, which would you pick?
    Thanks for any input.
    Brian
  2. macmaster05
    macmaster05 Senor Member
    4,050
    729
    A question like this probably hasn't been asked in a long time.
    1. Draw - both are very reliable, proven cars.
    2. You dont know, but there's a good chance nothing will happen. There's a 200,000+ mile club here, and taxis go the distance all the time.
    3. Styling and technology are the main differences. Plus more cargo room.
    4. I'd pick the Gen II, but even $8k still sounds like a lot for one with 162k miles. I'm guessing your budget isn't big, otherwise you wouldn't be in this quandary. Just a couple more thousand dollars and you could easily get a Gen II under 100k miles.
  3. Patrick Wong
    18,200
    6,472
    I agree that if possible, you should increase your vehicle purchasing budget so that you can buy a 2G with a <100K mile odometer reading. If this is not possible maybe you should buy a used Corolla or similar vehicle.
    Any significant Prius failure out of warranty will end costing you four-digits. Although the failure % is not high, that is not comforting if the failure happens to you.
  4. MtnHighPrius
    MtnHighPrius Junior Member
    Denver, Colorado
    Consider how many miles will you will be adding. If low I'd go for the '06 but have it checked out by a Hybrid Mechanic. And look for a ticking sound coming from the gas engine. A lifter adjustment will fix it but will be costly. If they fix it than it would be worth it. It could also be a sign of running low on motor oil to often or not changing enough or both. These cars can take mileage but not if they are abused.
    The 06 is more advanced than the 1st generation('01-'03). I am a courier and bought a II Gen '04 w/120,000 miles in Aug. for $8000 and it now has 145,000 and it had the ticking lifters but I knew it was ok cause its not really harmful. But I have to say it's annoying.
    Other than that it has been a great car and getting 44 mpg is not bad either.
  5. GigaTigga
    GigaTigga New Member
    84
    Nebraska
    Not that this will help much with your decision but I recently purchased a 05 with 106k that was a package with nav, bt, etc for 9000. Depending on the package the Gen 2 may not be a good deal.
    From what I have read here, you're more likely to run into battery and transaxle failures in the Gen 1 vs the Gen 2.
    SCH-I800 ?
  6. jmooney
    jmooney New Member
    23
    Arkansas
    $8k is too much, we just bought an 06' for a little more than that with half the miles from a Toyota dealer. Buy a new yaris or something else.
  7. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Or look around a bit more and hopefully find a Gen2 with a lot less miles for not very much more money.
  8. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    162K is a LOT of miles, and the Prius is a complicated car. I'd keep shopping or consider the purchase of a non-hybrid.
  9. bkebschull
    Castaic, CA
    Thanks, everyone, for the input. I guess perhaps used cars in Los Angeles are a little more than in other places. An '06 with, say, 80K miles out here would be in the $11K-14K range.
    I ended up buying an '07 Hyundai Elantra with 70K miles yesterday for $7.3K. Not really what I wanted, but it'll do as a car I can bequeath to my son next year when he turns 16, and then get what I really want.
    Thanks again.
