low miles to high miles switch
Discussion in 'Gen 3 Prius Main Forum' started by jry423, May 6, 2015.
  1. jry423
    jry423 Member
    96
    37
    Ohio
    Hi! I'm typically a pretty low mileage driver. I've got a 5 mile commute to work, and my car is basically used only on solo trips. My wife has a Chevy Traverse that we use on longer trips and family outings since we have five kids.
    I'm going back to school to get my masters, most of the classes are able to be done online, but there is one section that will require me to drive to class 2-3 days a week, depending on the semester. It's 126 miles each way, so about 750 miles a week, plus the rest of my normal driving will average to about 800 miles a week for the next 2 years. It's a year round program, with summer session being 2 days a week, the rest is 3...
    Long story short, I'll have about 80,000 miles on the car by the time I'm done, and that's not counting my occasional road trips I take for runs, etc. Is there anything I should do differently for this kind of mileage? It'll mostly be interstate, 70-75mph, except the first 20 miles from home is state route, so it's 55mph.
    I do have extended warranty on the car, which will be expired at 60,000 miles I believe.
    Should I do oil and filter change every 5,000 miles, or am I okay to stretch them out to 10-15k? I don't want to over maintain, but I don't want to neglect, either.
    Also, is it possible to add xm to factory radio, or no?
  2. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Your car will be fine using the standard maintenance interval of 10,000 miles on 0W-20 full synthetic.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Daddy Dave and Priusguy78213 like this.
  4. jry423
    jry423 Member
    96
    37
    Ohio
    Should I cancel the extended warranty then?
  5. bisco
    49,481
    yes.
    Priusguy78213 and WE0H like this.
  6. mrbigh
    3,686
    699
    Long Island, NY
    YES
  7. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Use your cruise control and Auto A/C windows up! Higher speeds and longer drive you will find wind resistance your greatest mileage obstacle. Clean your cabin air filter and the synthetic oil every 10,000 is a must with the best oil filter you can find (Bosch and Castrol Edge)
    Sen
  8. John Bergendahl
    102
    17
    gulfport,ms
    Oil every 10000 oops I been changing every 5k with 0w20. I'm at 30k have not did trans fluid yet.bolts probably going to be pain to get loose .
  9. nicoj36
    nicoj36 Active Member
    495
    158
    I wouldn't max it til 10k miles for long commutes like that. Maybe 6k-8k miles for me. 10k is only recommended if you do light driving. 126 mile commutes aren't!
    Also, don't forget tire rotations every oil change. And car wash lol.
  10. Mendel Leisk
    38,721
    I'd disagree, say a longer oil change interval is more appropriate for a car consistently doing long drives. The oil tends to get fully warmed, lasts longer than with a car doing lots of short drives.
    CR94 and FuelMiser like this.
  11. nicoj36
    495
    158
    Not for me, once I hit 6k-8k I start to feel less performance and mpg, and I personally don't prefer to max out on things just cause someone says I can. You may check your oil too if its still clean or dirty at that rate. I do 800 mile roundtrip commutes every 2 weeks from South and North California, and occasional drives to Nevada, Arizona, and Texas. I wouldn't feel comfortable driving those with an 8k old oil. But then again it's personal preference.
    John Bergendahl likes this.
  12. Paul Schenck
    523
    306
    Fresno, California
    I've done my last oil change on my 2005 I'll be replacing the engine when it hits 400,000. You can throw out $35. Of perfectly good synthetic oil or just change the oil filter and add a quart.
    I suppose I might have gotten 800,000 miles on it if I had changed it at 5000 miles but that is just scary thinking, right?
    iPhone ?
  13. John Bergendahl
    102
    17
    gulfport,ms
    I'm programmed on the 5000 mile oil change just peace of mind I guess,I'm going to ride till battery acts up.hopefully by time I need one the market for them is more cheaper and reliable ...
