Low oil warning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sishoch, Jun 12, 2022.
  1. Sishoch
    Sishoch Junior Member
    Have a 2005 with 138,000 miles, owned from new. It was parked for four years while I was out of state but I've been driving it daily for a few months. Occasionally, the red triangle would flash and it would beep. Tried to read the codes but there weren't any. Perused this forum and discovered it was a sign of low oil. Had to add two quarts to get above the fill line. Thank you all for saving my engine.
    But why the cryptic signal? Shouldn't there be a low oil light on the dash and shouldn't it cause an engine code? All it said on the display was "problem" which was no help at all.
    For the record, it never burned oil before I parked it and I rarely had to add oil. Oil changed every 5000 miles.
  2. JC91006
    16,479
    8,395
    As these engines get older, they will start burning oil. Have you had a habit of checking oil level to say "it never burned oil before"? After it sitting for 4 years, you didn't change the oil before driving it again?
    49,399
    low oil pressure notification would be nice, but toyota trusts that you'll keep an eye on it apparently.
    you're fortunate. for most people, a blown engine is the only indicator
  4. PriusCamper
    PriusCamper Senior Member
    11,070
    4,506
    Pacific Northwest, USA
    Car sits for 4 years and you just cross your fingers and hope for the best? Like not even checking the dipstick? Wow!
    This website may of saved your engine this time, but with you car care ethic you should probably start shopping for a new car ASAP.
  5. PriusCamper
    11,070
    4,506
    I wonder what's so scary about a dipstick? One time someone with 300K miles on a Prius asked me how to check the oil level... How that prius did that well for that many miles is beyond me.
  6. bisco
    49,399
    i suspect most haven't been taught. manufacturers/dealers don't encourage it.
    maybe we need to go back to more practical life classes in high school
    nancytheprius likes this.
  7. Sishoch
    For the record, I changed the oil, tire, wipers, and 12v battery before I started driving it. I also cleaned it (there was a rabbit living under the hood) and had it painted.
  8. JC91006
    16,479
    8,395
    How many miles did you drive since the oil change?
  9. bisco
    49,399
    2 quarts over a few months equals 1 qt/2,250 miles
  10. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    I knew how to check a dipstick long before high school.
  11. bisco
    49,399
    one of the fortunate ones
  12. dolj
    dolj Senior Member
    7,632
    3,850
    Wellington, New Zealand
    With the car sitting for four years, the oil return holes in the pistons might have got gummed up. To test this, you could try doing a piston soak using Berrymans B12. Some have reported success trying this.
  13. Mendel Leisk
    38,662
    Yeah, when we went to our Toyota dealership's "new owners night", the service manager gave us a tour of the service department, and proclaimed "our goal is to ensure you never need to pop the hood"... :rolleyes:
  14. Sishoch
    About 4000 miles in 4 months
