Low RPM Engine Rumble
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by aNutterPrius, Feb 9, 2024.
  1. aNutterPrius
    aNutterPrius New Member
    New York
    About a month ago, CEL came on for a misfire P0303. We took the EGR system out and cleaned it thouroughly with power washer, etc. The cooler, the EGR, the pipe and the intake manifold were all cleaned. The cooler was very clogged, but looked good when we put it back in. Also changed the spark plugs and the ignition coils. Car has about 80,000 miles.
    Fast forward about a week, and we started to get an engine rumble at low RPMs usually as we take the foot off the gas. The rumble appears to have gotten worse and more frequent over the last few weeks.
    Oil consumption is minimal, coolent levels are good and not dropping. We've tried disconnecting the EGR system plug, CEL came on (as it should) but the rumble remained. Other than that, no CEL. Gas mileage still decent, over 48 possible with a little effort.
    Any thoughts? Could we have dislodged some gunk that is clogging up somewhere? What are the next diagnostic steps?
  2. aNutterPrius
    New York
    Also, I forgot to ask, what is the time frame that this becomes dangerous to the longevity of the car?
  3. Mendel Leisk
    38,873
    Swap cylinder 3 igniter with another, see if code follows. If not:
    Check integrity of head gasket. Boroscope inspection of combustion chamber with cooling system pressurized (looking for coolant seeping into cylinders) is the usual method. Also look for exceptionally clean piston tops.
    #3 Mendel Leisk, Feb 10, 2024
  4. aNutterPrius
    New York
    The P0303 was solved by cleaning the EGR, the cooler, and the intake manifold.
    We haven't had any misfires recorded since then.
    The knocking at low rpms was not occuring at all before we cleaned the EGR. Now we are experiencing knocking when we ease off the gas. This is brand new behavior that we didn't experience at all prior to the cleaning.
  5. bisco
    49,693
    if the head gasket isn't blown yet, longevity should be fine, but look into the coolant pump tsb.
  6. CR94
    CR94 Senior Member
    2,642
    1,139
    Northwestern S.C.
    Check for vacuum leaks, for example a hose loose or disconnected.
  7. mjoo
    mjoo Senior Member
    1,129
    1,318
    Michigan
    Try some fuel system cleaner
    SM-A536V ?
