low temperature indicator
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nhalber, Dec 6, 2005.
  1. nhalber
    nhalber Junior Member
    83
    Marblehead
    Why is it important to know that it is 37 degrees or below?
  2. brandon
    brandon Member
    771
    Manhattan, KS
    I believe roadways, under the certain conditions, can start to become slippery at that temperature. Better to find out at 37 degrees than 32 degrees?
  3. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    There are many posts in here on that subject if you do a search.
    Briefly, it is so you can tell that the roads or bridges might freeze up. Most agree it is not all that useful in very cold climates siince it stays on all winter. Some cover it with electric tape since they consider it an annoyance.
  4. TALON
    TALON New Member
    37
    Antioch,Ca
    In most locations ice on the road could be fatal.
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Has anyone actually seen ice on the road when the temprature on the MFD is 37 deg F? I haven't, but there are obviously conditions I haven't seen. Not leftover hard packed snow that I can see, that can be on the road at tempratures way above 37, but the stuff I can't see like black ice.
    The problem with this icon is that it comes on when it isn't needed and stays on. People learn to ignore it fairly quickly even if they don't want to. It's like saying "the sky is falling" when it really isn't, people will soon ignore you. There was a metaphor about wolves I think.
  6. jwe8f
    jwe8f New Member
    174
    Indiana
    Sure. When the temp is rising from below freezing. Ice can easily still be on the roads, and slippery too, because it's melting.
    Also there's that old saying about bridges freezing first and thawing last...
  7. Tideland Prius
    16,445
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Guilty as charged
    :rolleyes:
