Low temps and Auto/HV modes
Discussion in 'Gen 5 Prius Technical Discussion' started by Rafsdhc6, Nov 18, 2023.
  1. Rafsdhc6
    Rafsdhc6 New Member
    Ontario
    2023 Prius Prime
    XSE
    I have a short commute of around 6-7 miles one way with a quick portion of it is on the highway. The Highway is a quarter mile away from my house.
    Usually I just cruise on EV but sometimes I do have to be quick as it’s a busy stretch so I’ll set it to Auto. My question from engine longevity stand point and low temps going well below 20f, should I just switch to HV and let the engine warm up before I’m on the highway or keep it on Auto and let the engine warm up during highway acceleration?
    reallyreal likes this.
    49,357
    i would switch to hv right away. it has pretty much been determined that auto was useless on gen 4 and likely no better now.
    there haven't been a lot of gen 4 problems, but if you intend on keeping the car, the engine will survive much longer if it is properly warmed up whenever needed for acceleration.
    Rafsdhc6 and Louis19 like this.
  3. BiomedO1
    BiomedO1 Senior Member
    1,434
    780
    SacTown, Ca
    I'm with Bisco on that one; engine should be warm when you demand power from it. On my 4th gen; you need to get over 80 mph, 128 Kmh for the ICE to kick-on. My understanding is that you have a larger engine and battery (capable of 40 miles), in your gen5. You should be able to manage your commute without using your ICE - unless temperatures drops below optimum battery usage conditions. In that case, the ICE will simply turn-on.
    IMHO, if you park your car at work or home and the ICE is running; I would probably let the car complete it's warm-up phase before shutting-down the motor.
  4. Louis19
    Louis19 Active Member
    373
    335
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    I would suggest to switch to HV right away for engine warm up and cabin heating because below 20F the heatpump will struggle and suck alot of electricity just to try to warm up the cabin . When the engine is warm and the cabin is cosy then flip to EV mode.;) the engine is a very efficient heat generator.
    For short trips , of a few kilometres ,where the engine would not have enough time to warm up enough , keep it in EV and switch on the seat and steering heaters :cool:
    #4 Louis19, Nov 18, 2023
    Rafsdhc6 likes this.
  5. Trollbait
    11,494
    It is a 7 mile trip. If the engine has to come on for extra heating or defogging, I'd just leave it on for the whole trip to give more time for moisture to be driven out of the oil.
  6. Rafsdhc6
    Rafsdhc6 New Member
    Ontario
    2023 Prius Prime
    XSE
    I occasionally enjoy spirited driving and I find the Auto mode on Gen5 really nice, cuts out the engine noise considerably while having lots of power for passing.
    But it makes sense to warm up the engine before hand. I was secretly hoping when in Auto the oil would be secretly heated and ready for acceleration :D
    Louis19 and bisco like this.
  7. Louis19
    373
    335
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    I would stay away from using AutoEV mode in cold weather ....well finally all the seasons . Stick to EV or HV.
    Rafsdhc6 and bisco like this.
  8. Louis19
    373
    335
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    I really like your secretly hopes......when I acquired my prime in 2022 ...I realized that this car was a saucerfull of secrets :D
