Low Tire Pressure indicator intermitantly comes on.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fireplug, Jul 9, 2019.
  1. Fireplug
    Fireplug Junior Member
    While driving at highway speeds, the low pressure light will intermittently come on every once in a while and then go off fairly quick. I can go several days without it coming back on, not sure what would cause this .
  2. RobertK
    RobertK Member
    128
    40
    Norfolk, VA
    You might have a tire that is marginally low. The tire warms up as you drive, causing the air pressure to rise above the low pressure threshold and turning off the light
    Set all of your tires to the correct pressure after the car has not been driven for 6+ hours, then reset the TPMS using the button under the steering column. If you don't have a tire inflation device at home, set the pressure 5-8 lbs. over the cold setting at a gas station and then check them after the car has not been driven for 8+ hours. You can bleed the tires down to the desired values and reset the TPMS.
    If the TPMS light is flashing, you may have a bad TPMS sensor. The life of a TPMS sensor battery is about 10 years or 100k miles. If you have access to Techstream you can check the battery level in the sensors.
    Fireplug and Mendel Leisk like this.
  3. Mendel Leisk
    38,648
    Good answer.
    #3 Mendel Leisk, Jul 10, 2019
  4. Fireplug
    I just took your advice, will wait and see if that corrects it. Thanks.
