Low Tire Pressure Warning System
Discussion in 'Gen 2 Prius Technical Discussion' started by Rest, Mar 6, 2007.
  1. Rest
    Rest Active Member
    1,210
    53
    CA
    How does this system work? Do we get an idicator light based when a tire or tires pressure reaches a set minimum? Or does it warn us based on a difference in pressures between all four tires?
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) See Pages 150-152 of your 2007 Owner's Manual. Sensors are located inside your wheels at the base of the valve stem.
  3. Rest
    Rest Active Member
    1,210
    53
    CA
    I know where the sensors are located.
    I should point out I had a leak in one of my rear tires. It turned out to be a nail and I had it repaired. The warning light came on again a few days later and the tire pressure was not low. The repair place said that maybe the system detects one tire that is not near the same pressure as the others. So they lowered all the other tires pressure to factory specs. I don't think that is how the system works. I believe each tire is independent of the other and you get a warning when the tire pressure goes to 25% of what was put in. But I think the place that fixed it put lower than what I had in to start with (42 front/ 40 rear). So I am thinking that is what set off the warning. I am guessing but I believe I have to reset the warning system.....yes?
    One note, when I raised the tire pressures to 42/40, I never reset the system and didn't get any warnings.
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(Rest @ Mar 6 2007, 05:40 PM) [snapback]401227[/snapback]</div>
    The warning lights when pressure drops 25% of the set value in any one tire. At 42/40 you will have to lose more than 25% before the light comes on. Ensure all the tires are at the desired pressure then reset the sensors as per the owners manual.
  5. Rest
    Rest Active Member
    1,210
    53
    CA
    Okay so after I raised the pressure to 42/40 if I wanted to keep that 25% loss warning then I had to reset the system. It all makes sense now, thanks.
    One more question. When one of the sensor batteries goes dead how can I tell which tire the sensor belongs to, without taking my Prius to a dealership?
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    <div class='quotetop'>QUOTE(Rest @ Mar 6 2007, 02:40 PM) [snapback]401227[/snapback]</div>
    You have identified why you got the second warning. EVERY TIME you change the pressure, rotate the tires, get a flat, boost the pressure, drop the pressure, get new tires, etc., etc., take 15 seconds to reset the system. The TPMS doesn't know what your tire air pressure is, only if it decreases from when it was reset. No reset, it can get confused.
    Regarding battery life, ask this question again in a few years. Those are long-life batteries. You'll run the tread off your Integrity tires long before the battery wears down.
  7. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(Rest @ Mar 6 2007, 09:27 PM) [snapback]401457[/snapback]</div>
    Actually, you can't. If a sensor battery fails, the warning light will be on all of the time. Check your tires. If they are all okay, the only way to know which wheel has a failed sensor battery is to take the car to a dealer who has a scan tool who can get a reading from individual wheels. Even then he will need to maipulate the pressures to figure out which wheel is which.
    Except if you encounter a faulty battery in a sensor, this is a long way off. I think they are supposed to last ten years.
  8. Rest
    Rest Active Member
    1,210
    53
    CA
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 7 2007, 01:33 AM) [snapback]401463[/snapback]</div>
    Rarely will anyone get the rated 10year life out of the batteries. Other vehicles use similiar systems with the same type 10 year battery and only get 3 to 5 years life.
  9. Bill Merchant
    4,096
    81
    So, when you replace your tires, you can prophylactically replace the battery. What's the problem?
  10. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 7 2007, 03:26 AM) [snapback]401525[/snapback]</div>
    Problem is............. you cannot replace just the battery in a tire pressure sensor. You have to replace the sensor.... About $150 each if memory serves me correctly.
  11. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
  12. Allannde
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(Bear68 @ Mar 10 2007, 11:55 AM) [snapback]403453[/snapback]</div>
    I think it is $104 each. Less, but still a lot.
    galaxee
    Thanks again for your summary of the system!
    Is the $104 cost correct?
    Is the advice regarding determination of which wheel might have a failed battery correct?
    Is there a preventative (prophylatic) procedure other than simply replacing the sensor units when changing tires?
    As these things age, they may be troublesome unless we simply learn to ignore the warning light and check the tires the old fashoned way.
  13. galaxee
    9,810
    465
    MD
    when DocVijay got some new sensors for his new rims that's what he paid, but that was like a year ago if not more and costs do go up.
    for the rest, i'll have to answer tonight when DH gets home. for sure the system is far from perfect.
  14. Bill Merchant
    4,096
    81
    I stand corrected, sorry. What were they thinking in not making the battery replaceable?
  15. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 10 2007, 05:39 PM) [snapback]403503[/snapback]</div>
    Weird thing is that the service manual tells you to rip the battery out of it for recycling before throwing the sensor away! Looks like it might be soldered in. I'd like to look at one and see if it could be replaced by someone not afraid of a soldering iron.
    [attachmentid=6842]
    - Tom
      File size:
      61.6 KB
      774
  16. Allannde
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 10 2007, 02:39 PM) [snapback]403503[/snapback]</div>
    If you think about it , Bill, those things get thrown about rather violently. That battery needs to be held tight to keep from flying off. It is not just the spinning but the bumps too. That doesn't even consider the occasional tire machine.
  17. Mary Snyder
    Mary Snyder New Member
    132
    <div class='quotetop'>QUOTE(Bill Merchant @ Mar 7 2007, 12:33 AM) [snapback]401463[/snapback]</div>
    Bill, how do you reset the system?. Which buttons do you hold and where are they?
    Mary
  18. Allannde
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(Masnyd @ Mar 10 2007, 05:55 PM) [snapback]403569[/snapback]</div>
    Hi Mary
    Bill must be away from his computer.
    The button is under the steering wheel at the bottom of the dash to the right of the button for the Smart Key. You must first set the tire pressures to the level that you prefer. Then hold down the button for the TPMS until the warning light on the dash flashes three times (it should be about 15 seconds). That is all. It is reset to the new pressures. If a tire defates to 75% of the set pressure, the warning light will come on.
  19. Bill Merchant
    4,096
    81
    Allannde was right, I was eating dinner...
    As a hint from another post, if you think 25% is too much of a drop, you can overinflate your tires by 10%, reset the TPMS, then reduce the tire pressure to the level you want to drive at. Now you'll get a warning when a tire is down 15%. Other ratios also work.
  20. galaxee
    9,810
    465
    MD
    <div class='quotetop'>QUOTE(Allannde @ Mar 10 2007, 06:51 PM) [snapback]403489[/snapback]</div>
    exactly right.
    no, when the sensor fails it fails. nothing you can do to stop it from happening.
