Low Tire Pressure
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Go-Green-Pal, Apr 11, 2021.
  1. Go-Green-Pal
    Go-Green-Pal Member
    73
    43
    Greenville, NC
    2018 Prius
    I have a 2018 Toyota Prius 3. Everything was going fine. I filled up gas on Friday, the 9th of April. I usually check my tire pressure and fill air if needed when I fill gas. I checked the tire pressure and all were fine. Nonetheless, I filled air (as there is no harm and the system at the gas station will automatically stop once the desired pressure is reached).
    On Saturday, I took a trip which involved driving about 100 miles. I did not have any issues during the trip. On Saturday evening when I went for grocery shopping, I noticed a new light on the dashboard. I needed to look it up using the manual. It said "Low Tire Pressure Warning". I was surprised considering only the previous day I filled air. My initial reaction was there must be something wrong with the warning light system.
    This (sunday) morning, I checked the tire pressure in cold conditions. They were indeed low and awfully low at the. The two front tires were at 26 and 20 (where as 36 is recommended). The two back tires were at 26 and 25 (where as 35 is recommended). This means warning light system is really working. Also, the cause is most probably not due to tyre puncture (as in that case pressure will be low in only one of the tires that got punctured). So, I have no clue what is going on.
    I will fill air again later today and hopefully the light will be gone and everything will be fine. But, I thought I will check with you folks as to whether anyone has encountered anything similar and do you have any idea what is going on with my car?
    49,507
    perhaps the filling station system is broken?
    you should always use a reasonable quality gauge, and check the tires 'cold' before driving in the morning
  3. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    There is nothing going on with your car, but maybe there is something wrong with the gas station's air pump. Was the air temperature higher when you supposedly filled your tires with air? Certainly increasing temperature will result in a higher pressure in your tires as the molecules become more energized, and the opposite will occur as temperatures are lowered, but that should only account for a couple of PSI, unless we are talking about severe temperature changes. Is it possible that the gauge on the pump actually allows air to escape from your tires if it sees the pressure as too high. It shouldn't work that way, but maybe it is defective. It's probably worth trying a different gas station's air pump. Also, I always carry an analog tire gauge to check the tire pressures as I'm filling them with air.
  4. jteran5
    jteran5 Active Member
    411
    202
    2019 Prius
    XLE AWD-e
    I like to check my tires cold, before driving any distance. I bought a nice, cheap air compressor that connects to the 12v plug by the center armrest. I did a lot of research as I had to find one that used only 10A (good ones use 15A), but wasn't terribly slow either. I ended up using Tacklife M2. It is SURPRISINGLY fast. I top off from 35 up to 41 in less than 30 seconds. I wanted something j could use every month or so to make sure pressure is appropriate as weather temps vary a lot.
    I usually over inflate my desired psi to account for slight loss when removing the connector. I then use a tire gauge that allows me to release air little by little til I hit the psi I want. I've been happy with 40/39 f/r and it's still very comfortable.
    Link to the compressor I'm using. The blue one had a pricing error and got it for $25 on Amazon TACKLIFE M2 12V DC Digital Auto Tire Inflator Portable Air Compressor – Tacklife Tools
    And the tire gauge I picked up from lowes. It was $5 during the holiday season as a stocking stuffer. I bought like 4 or 5 to have around.
    https://www.lowes.com/pd/Kobalt-Digital-Tire-Gauge/50126544
    #4 jteran5, Apr 11, 2021
    bisco and davecook89t like this.
  5. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    I agree with having a portable compressor. I have one of these... it runs off the cigarette lighter in your car. Loud; a bit slow; but gets the job done.
  6. fuzzy1
    10,172
    Was the gas station system broken, and let air out of your tires until they reached a too-low setpoint?
    I use a bicycle floor pump at home to top up my tires. While it does involve a bit of labor, it is quicker than driving anywhere to top up, and it it guarantees that I'm setting cold pressure, not warmed or half-warmed pressure.
    2ndPrius2015 and Mendel Leisk like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    MAJOR MISTAKE.
    You can NOT trust any "public" tire gauge like that.
    Get your own.
    2ndPrius2015 likes this.
  8. Mendel Leisk
    38,735
    Maybe it didn’t reach desired air pressure. I’ve dealt with anemic gas station pumps, barely enough oomph; they come to a standstill at some pressure. Maybe in your case that standstill was after some air bled out? Did you check pressures with your gauge, after “filling”?
    See the above is close to what @fuzzy1 said. Also, I do the same as:
    alanclarkeau likes this.
  9. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Since you are in North Carolina, has there been wild temperature swings? Like one day its 80 degrees and the next day its 40 and snowing?
    Because if you filled up on a warm/hot day and the next day its cold, the pressure will be lower because temperature does affect tire pressures. Only fill up when the tires are cold and on cold days or when its not predicted to have a temperature swing.
  10. bisco
    49,507
    have you rechecked it?
  11. Go-Green-Pal
    Go-Green-Pal Member
    73
    43
    Greenville, NC
    2018 Prius
    Thanks to everyone who weighed in. As many of you correctly said, there is nothing wrong with my car. The system at the gas station was malfunctioning. I went to a different gas station this evening and filled air (I had to pay $3.00 for it and I thought air is free) and now the light is gone. Even in the new gas station the system is not great and I could not set the pressure to what I wanted. So, I just set to 32 which is the default in that system (they had a + and - to adjust desired psi, but it is not working). Even with that 32, the low pressure light went off. But, I am still technically at low pressure as the recommendation is 36 for front tires and 35 for back tires. I will take care of it in the next few days by visiting a gas station that has a better system.
    I am now seriously considering buying my own inflator as some of you suggested.
    davecook89t likes this.
  12. jteran5
    411
    202
    2019 Prius
    XLE AWD-e
    FYI. The compressor I'm using has a pricing mistake for the orange one. Amazon is doing 15% off by checking the box and you can also use the promo code : CND6TV3R. It will bring the price down to $24. It's not a bad price and it won't blow your fuse either. (I tried the viair and the 15A was too strong and blew my fuse. Tried a similar one and same thing.
  13. jteran5
    411
    202
    2019 Prius
    XLE AWD-e
  14. sam spade 2
    7,035
    2,788
    2017 Prius c
    Few people actually have compressors; many have their own gauges.
    Ask around of "tire shops" in your area.
    There usually will be one or more that provides free air service......that really is free.
    If you have your own gauge, you will know before going there if you actually need air or not.
  15. fuzzy1
    10,172
    I'm doubting this part, based both on past responses during my time here, and the common and very easy availability of such products from all the hardware / automotive / cycling places.
    This part is true. But nearly all drivers should have their own gauges.
  16. bisco
    49,507
    3 bucks to fill your tires? we gave up on that years ago. stations tried and failed
  17. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    You might also want to check the valve core in each tire for tightness. And when you get all the tire pressures set to where you want them on a cold morning before the sun comes up, make sure you run through the dashboard TPMS reset instructions in the owner's manual to reset your calibration point.
  18. sam spade 2
    7,035
    2,788
    2017 Prius c
    People "on here" tend to be car enthusiasts and do not represent the public at large.
    Doubt it all you want.
    If you care, take a survey of random people and I think you will find that LESS than 1 in 10 own any kind of air compressor.
  19. Mendel Leisk
    38,735
    Stuff I’ve accumulated, with not a lot of effort or expense:
    Car with a spare (yeah, pretty obvious, but apparently they’re getting rarer...)
    BlackJack tire plug repair kit (used it close to 1/2 doz times now, on our Prius and other cars)
    Various tire pressure gauges
    Tread depth gauge
    Floor-style manual bicycle pumps, two currently (fine for topping up car tires, just a little exercise. Even capable of bringing complete flats back up, post-repair)
    Spritz bottle with some sudsy water (for checking for leaks)
    Durable insulated gloves
    Tire sized plastic bag (for tire storage and/or to lie on)
    High-vis vest and collapsible traffic cone
    Flashlight with magnetic base, with blink function.
    Small square of plywood (to provide better base for scissor jack, on rough or soft earth)
    Pair of wheel chocks (for wheel diagonally opposite the jacked up corner)
    #19 Mendel Leisk, Apr 12, 2021
