Low Traction Battery Problem w/ Prius at my Car Wash
Discussion in 'Gen 3 Prius Main Forum' started by lutece7, Aug 24, 2010.
  1. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    I have had my 2010 Prius 2010 for a year now. I have been taking my Prius to a full service car wash with the conveyor belt. They have always seemed ver Prius savvy. But the last couple of times, after getting in the car and driving away, the car seemed to hesitate upon initial acceleration. Then the problem goes away.
    The last time I took it to this car wash, I sat in the car, because I only needed the express exterior wash. About a third of the way through, the intrument panel said"
    "Low Traction Battery... put into Park" I did not obey the warning because I was afraid of putting it in Park while the conveyor belt system was pushing my Prius along. So I ignored it. By the end of the car wash, the engine had shut down. I had to start it up and drive out, and I got that same momentary, initial hesitation as I accelerated, like before. The hesitation went away after that.
    Now, I am afraid to take it to the car wash again, and I am afraid to take it to Toyota because they might blame me or the Car wash for abuse. Besides, it only happens after getting off the conveyor belt system at the car wash.
    I thought I would check here and see if anyone knows what might be going on before I go to Toyota. I don't completely trust Toyota.
    I have had the recall issue fixed on this vehicle, by the way.
  2. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    How does the conveyor belt move your Prius. does it requires the wheels to be rolling? If not, putting it in "Park" is actually safer for you.
    It sounds like your Prius was simply draining the Traction Battery low for "idling" there in the car wash with full power on. In fact, if the wheels are not required to roll freely, turn off the power might be even better. I don't see why you have to keep the power of the car on while it's in the car wash. In fact it sounds down right dangerous to me. Nobody keeps their car's power on in the car wash. Was it a requirement of the car wash?
  3. Bob64
    1,540
    92
    Virginia
    Are you turning off your a/c and electrical stuff during the wash?
    douglasjre likes this.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The car washes I've been to that pull you through have you keep the car in neutral. I don't think park will work at all as one of your wheels will end up being locked up.
    The HV battery CANNOT charge while in neutral. Just don't use the AC while going thru the car wash to keep it from draining the HV battery too rapidly.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I take my Prius to the car wash (and every one I've used pulls the car along a track, so the wheels must turn), and never had an issue. The only thing I turn off is the audio.
  6. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Agreed, usually the engine will kick on to charge the low HV battery with A/C on, but apparently not in neutral.
  7. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    if you're on a conveyor belt, surely your wheels DON'T need to turn? my guess is the sign says put it in N to stop stupid people forgetting they're in D and destroying the car wash.
  8. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    yes, my wheels still turn in in the car wash, and you must put the car in neutral. Yes, I DID have my AC on. GSW, you might have hit on something, In Park, when the battery gets low because the AC is on, the engine turns on as needed. But maybe it doesn't when in neutral! I need to try it and this time, turn off the AC.
    Still wonder why the hesitation when pulling out. I would give it a little gas, no reaction, then reaction.
  9. Flaninacupboard
    1,297
    213
    Midlands - UK
    so how does it make your car move? blocks behind the wheels or something?
  10. archermoo
    archermoo New Member
    118
    Pittsburg, CA
    If the state of charge on the traction battery is low enough it won't be used for acceleration when you start moving. The delay would be the amount of time it takes for the car to spin up the ICE and start it to provide the needed power. Once your SoC is high enough you lose the delay.
  11. bisco
    49,382
    i think they guide one of your front wheels onto a conveyor belt that has ridges lrge enough to catch the tire securelyl like when you pull onto a lift at the mechanic.
  12. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    flanin, I think there are rollers behind my rear wheels, those rollers are on a conveyor belt and push my rear wheels which are in a track. The same way it has been doing it in every car wash I have seen in the bast 40 years.
    archermoo, you explanation sounds plausible. thanks. I will get another car wash and report back soon.
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Just turn off the headlights, climate control, and audio system when in neutral and it will be OK. Might help if you can arrange to arrive at the car wash with 5 or 6 bars in the battery.
  14. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    What temp do you set A/C to? How hard is it working?
  15. JerrySC
    JerrySC New Member
    29
    SC
    If your car wash is a roll through wash, like alot of $20+ washes are, you can't have your power button off. That will automatically place your transmission in Park, effectively stopping the wheels from rolling along while pushed from the converyor rollers behind them. Others posters advising to shut down uneeded devices are correct in helping save the battery. The car has to remain in neutral to roll freely. Of course for a "touch free" wash where the car remains stationary and the equipment moves around the car, do as you like. (Personally I have never had a really good wash from a touchfree.)
  16. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    I actually avoid ALL car washes and do it myself in my own garage even in the sub-zero winter here in Canada. It's not for saving money but to save the paint from getting swirling scratches that looks ugly in the sun. I use a bucket of warm water (no soap)and half a dz of microfibre cloths and just wipe the car without having to actually hose the car with water first. Always turn the microfibre cloths to use a clean spot. Reusing a dirty part of the microfibre may scratch the paint.
    No soap, no chemicals, no mess, no scratches, no fees, no problems. Good workout and yet less than 1/2 hour, less time than going to those automatic car washes and line up and driving back and forth. Can do it in your jammies and or boxers or bikinies:cool:
    Did I mention NO SCRATCHES to the paint?
  17. HTMLSpinnr
    5,339
    917
    251
    This is untrue - you CAN actually put the car in IG-ON and in neutral. This would eliminate the HV battery draw, and assuming the blower and other accessories were off, wouldn't tax the 12V battery either.
    The scratches are what keep me out of anything but a touchless for now. Then again, my dealer often has the car washed as part of the service, and I'm not entirely certain what they use.
  18. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    I actually experienced this same issue a few days ago. I usually wash my car myself but it was 106 degrees outside here in Ft.Worth, TX and I just couldn't get up the energy to go outside and wash it. Besides, when it is that hot, the darned water tends to evaporate before I have a chance to rinse the soap off.
    Anyway, so I took it to a full-service car wash and they told me to put it in neutral. Everything was okay until about half-way through and I got the warning message and a constant annoying beeping from the car telling me the HV battery was low and to put the car in drive or park.
    I wasn't sure what to do at first because I didn't want to do anything that would lock up my wheels since only one side of the car was on the conveyor. So I just turned off the A/C and anything else that was using power and waited until I got through the wash.
  19. Flaninacupboard
    1,297
    213
    Midlands - UK
    Never seen one that moves the car here, they all have moving rollers/jets etc.
  20. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Scratches are why, after five black vehicles and two dark blue vehicles, this one is Blizzard Pearl. ;)
    Kurt Davis and WE0H like this.
