Low Votlage on 12v Battery even with new battery.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, Jun 14, 2020.
  1. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Hello, Hope I post in the right thread
    My original Toyota 12v battery measure at 11.7-11.9v during the morning. I decide to the change the battery and it has been using for 3 days now and should well charged. It still show 11.8 -12v in the morning.
    So Cal weather 70-90F daily.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    You have a parasitic drain somewhere
  3. Tekken
    Tekken Member
    257
    77
    That's funny bro
    51,155
    prius doesn't bring up a low battery very well. put a charger on it. should be close to 13v. then monitor it every morning to see how far it drops. if it keeps dropping, something is draining it, or it is not being charged properly. you can measure that with the car 'ready'.
    ^tanks mention of a parasitic drain simply means that some fault in the car is draining the battery when it's off, more than toyota designed for.
    but you need to know if you have a good, fully charged battery first.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Nothing funny about it. What an odd comment to make.
    That is one possible cause for the extremely low voltages you are seeing.
    It is also possible that your new battery was not charged when you got it.......and the car itself is not capable of fully recovering a DEAD battery over a short time like 3 days.
    It is also possible that your charging system has failed. What is the voltage reading while the car is running (in "ready" mode) ?
  6. Tekken
    Tekken Member
    257
    77
    No, If I have my prius on Ready Mode, Aux 12v battery read at 14.1-14.4v and same as my Original Toyota battery 14.1v when Ready Mode is on.
    i don't have external AGM Charger. Don't know if can charge from my None AGM 12v battery?
  7. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "No, If I have my prius on Ready Mode, Aux 12v battery read at 14.1-14.4v and same as my Original Toyota battery 14.1v when Ready Mode is on. "
    That is the charging voltage of the Prius system; nothing to do with the health of your battery.
    "i don't have external AGM Charger. Don't know if can charge from my None AGM 12v battery?"
    You can't. You need a battery maintainer that charges your Prius aux 12V at 4 amps (or less; less takes longer...). A maintainer will taper off its charge as it approaches full charge; won't overcharge the battery.
  8. ChapmanF
    17,348
    The voltage when READY doesn't tell you the condition of the battery, just the condition of the DC/DC converter in the car. The good news is, given you're seeing the 14.1 to 14.4, the DC/DC converter would appear to be ok.
    Ed Beaty likes this.
  9. bisco
    51,155
    if you don't want to buy a volt meter, search for the instructions on how to read the voltage on the screen with car in acc mode.
    or you could go to an autoparts store for a free load test.
    what brand is it, and where did you buy it?
  10. Tekken
    Tekken Member
    257
    77
    that 11.8 to 12v from new Battery (ACDelco ACDB24R on Amazon ) read from My Prius Screen. I hope it's accurately from prius.
  11. bisco
    51,155
    yes, there's a small draw, so the battery is a little better than that
  12. sam spade 2
    7,035
    2,799
    2017 Prius c
    When the vehicle is running (in ready mode) you are NOT reading the actual battery voltage but the voltage of the charging system in the car.
    To read the actual battery, the car must have been OFF for a while.
    And to be sure that "phantom loads" aren't affecting THAT reading, one of the battery cables might need to be disconnected.
    AGM batteries are not THAT different. Any "good" charger will work fine.
    That does not include cheap trickle chargers......which are not fine for anything.
  13. sam spade 2
    7,035
    2,799
    2017 Prius c
    Can't what ??
    A normal, manual battery charger will be just fine......IF the capacity isn't WAY high and you disconnect it when the charging current nears zero.
  14. sam spade 2
    7,035
    2,799
    2017 Prius c
    11.8 V indicates that it only has about a 40% charge......and may not operate things properly.
  15. Tekken
    Tekken Member
    257
    77
    Ok.. let me run it couple more days and post back with result.
    That's why I read it in the morning with cool weather about 65-70 F
  16. ChapmanF
    17,348
    If "from My Prius Screen" in the above meant "from the Vehicle Signal Check screen on the MFD", that should be taken into account.
    As has been often covered here on PriusChat, including in a recent-enough thread to be fresh in memory, that vehicle signal check screen reads a voltage from the inside of the MFD where it is often half a volt or more lower than you would see at the battery. On any Prius I've owned, if the signal-check screen were showing 11.8 to 12, a battery measurement would be around 12.4 to 12.7.
  17. sam spade 2
    7,035
    2,799
    2017 Prius c
    The onboard charging system may NOT be able to fully charge the battery if it really IS very low.
    It would be a MUCH better plan to connect the charger that you have for a few hours........IF it has a meter to monitor the charging current.
    And why did you think mentioning the temperature would add any useful information to the discussion ??
  18. Tekken
    Tekken Member
    257
    77
    An update for a week of using this ACDelco Battery. I don't have charger to charge this ACDelco. I decided to return it as not function correctly
    ACDelco Battery
    Meter measured 12.39
    Prius Screen showed : 12v
    Original Totoya battery
    Meter measured : 12.27v
    Prius Screen showed 11.9v
    don't know how to tell the manufactory date on Totoya battery, it's looks good condition and hope it can last 1 more yr.
    MPG 56.1 on Los Angeles City street plus Freeway drive in Spring temperature.
    Save money to buy a set of New tires..
  19. bisco
    51,155
    post the code from the top of the battery, it has been covered before.
    at 12.27, you want to keep a close eye on it. depending on age, things can change quickly
  20. Tekken
    Tekken Member
    257
    77
    When you guy measure by meter, did you guys measure battery connected on car or without
    Original Toyota battery measure by metter
    without connect car 12.59v
    connect to car 12.27v
