lower fuel consumption with charged battery
Discussion in 'Prime Fuel Economy & EV Range' started by Gianmarco, Feb 3, 2025.
  1. Gianmarco
    Gianmarco New Member
    16
    Italia
    2018 Prius PHV
    Good morning,
    I would like to know if it is just my impression or is it reality.
    Does it make sense to use the Prius Prime in HV mode with a charged traction battery to reduce fuel consumption?
    It seems to me that with the traction battery charged (plug-in) and using the car in HV the fuel consumption is lower.
    I say this because I notice that the engine is off more time than when the traction battery is discharged.
  2. jetsam
    jetsam New Member
    17
    Badford
    2024 Prius Prime
    SE
    The more the engine's off, the less gas you use.
    Look at the thread about fuelling up; plenty of posts about refuelling once or twice a year in there.
    If you charge every night and your commute is short enough to do on battery, it's basically an electric car with some extra junk in the frunk. ;)
    I don't know much about the algorithm that decides when to run the engine (because mine has basically been an EV since I got it), but it makes sense that. It would run the engine less with more battery available. One of its goals is to keep the traction battery low enough for regenerative braking to be helpful, so it would need to use the electric motor in some capacity in any drive mode, with or without external charging.
  3. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    If you use a hybrid as an electric car, then the junk is most likely in the engine compartment and under the bottom of the car.:)
    51,155
    The prime will use some plugin electricity in hv mode for better mileage, but you have to weigh electric vs gas costs if that is the objective
  5. Gianmarco
    16
    Italia
    2018 Prius PHV
    Good morning,
    Thanks for your replies.
    I mainly use the Prius as an HV because the daily home-work distance exceeds the EV range. At work I don't have the option to charge it.
    So I charge the Prius at my house once or twice a week.
    With a 100% charged battery and HV (full hybrid) use, fuel consumption is lower compared to a flat battery. This is my impression.
    vvillovv likes this.
  6. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    I believe the Prime uses less gas after being plugged in and charged too.
    Have you noticed that some days when you get home or to work that the Prime has used more charge
    than on other days commutes?
    Or is the amount of charge used each day on the same commute very close to the same?
  7. bisco
    51,155
    You do realize it is compensating lower gas use with electricity?
    So you have to figure in both to calculate fuel consumption
  8. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    Well, impressions can be deceiving! There is no such thing as a "flat" battery in Prime. There is an EV portion that you fill up by plugging-in and there is an HV portion that is managed by the computer when operating in HV mode just like the normal Prius.
    Since you are carrying around the same weight whether there is EV charge or not, your gas MPG is likely exactly the same in either situation.
    If you're not using EV at all, why waste the electricity from your home charger to fill the EV portion? Just leave the battery in HV and run it like a standard Prius Hybrid.
    Gianmarco likes this.
  9. Gianmarco
    16
    Italia
    2018 Prius PHV
    Good morning, Thank you for answering my doubts. As you said, it's just an impression. I bought this Prius only 3 months ago and I'm doing some experiments. However, driving the Prius in HV with a 100% battery there is less use of the thermal engine because it is evident that there is no need to regenerate more current to avoid draining the traction battery too much, having a lot of energy reserve.
    I will do a test by calculating the actual liters refueled always with use in HV and traction battery 100% charged and then I will repeat the same test but with a discharged traction battery with only the reserve for HV use
  10. Numtini
    Numtini Member
    91
    91
    Cape Schrod
    2023 Prius Prime
    XSE
    Does your battery go down? Even in HV mode, mine will slowly drop until it hits 85% or so when it'll kind of even out.
    Gianmarco, vvillovv and bisco like this.
  11. vvillovv
    4,318
    1,499
    NY
    I see the same use of Traction Battery while in HV mode. It can be more or less usage depending on many things like speed, temp, length of drive, raise in elevation, driving downhill mostly.
    It can be hard to track unless one drives as close to the same route at the same speed and temp, every day.
  12. Gianmarco
    16
    Italia
    2018 Prius PHV
    I confirm. Mine behaves like this too.
  13. The Tramp
    The Tramp Italian Prius Expert
    369
    45
    Turin, Italy
    2020 Prius PHV
    Ciao Gianmarco,
    Ottimo acquisto!
    I have the car for over two years and yes, I can confirm that, when the battery is NOT indicating --%, it does consume less as it is using the battery just like the Prius 2 would do when it had a green battery.
    When you will eventually reach --%, the car will behave more like the Prius 2 with a blue battery.
    The solar panels we have will keep the battery topped up.
    Gianmarco and MAX2 like this.
  14. iskoos
    iskoos Active Member
    403
    251
    Orlando, FL
    This is not somebody's impression. It is more like the reality.
    I have been driving a 2017 PP for over a year, and I observed the same thing within several months of driving.
    Prius Prime has a great tendency to drive the vehicle as EV for the speeds from zero to 50mph (or even more) (as long as you don't floor the pedal and or going steep uphill). And this is when you are in HV mode obviously.
    I did some calculations and with the current gas prices (around $3 per gallon, sometimes less), it is more efficient to drive the vehicle in HV mode than EV mode (considering you don't have solar and have to pay for charging).
    I just like to keep some 10-15 miles EV range all the time just in case. But I realized soon that those 10-15 miles would not last more than a week. The car uses all the available high voltage battery even when you said you wanted to drive in HV (Hybrid Vehicle) mode.
    It doesn't give you a chance to preserve portion of the traction battery for a later use. I think it shouldn't have been this way. I mean, there should have been a mode that lets you keep the EV range you have and let you use it later when you wanted.
    2017 Prius Prime does not have this mode.
  15. BiomedO1
    BiomedO1 Senior Member
    2,821
    1,499
    SacTown, Ca
    the car is doing what's it's programmed to do - run in EV first!! In most locations electricity is cheaper than gasoline. If you really want to talk about efficiency, how many miles per Kwh are you getting and are you calculating that in your "feelings"??? Feelings are great but solid data points are better indicators. Has either of you calculated gas vs electricity usage breakeven points?
    the whole point of buying a car like this is efficiency, why are you not looking at the other side of the equation? Apple to orange comparisons don't make any senses.
    Just my 2-cents....
    PS you can reserve a portion of your traction battery for EV only travel; your just moving too slow and traveling too short of a distance to notice. anytime your traveling below around 40 mph it uses EV first - if your on the highway doing more than 50 mph in HV mode, your battery won't drain as much and will recharge. You'll see the EV portion assisting a bit to maintain speed, but you'll also see the traction battery charging as well.
    #15 BiomedO1, Jun 14, 2025
