Lower mileage after serpentine belt replaced
Discussion in 'Gen 2 Prius Main Forum' started by Joshace, Sep 13, 2016.
  1. Joshace
    Joshace Junior Member
    Prius Hybrid WAS consistently getting over 42 mpg but after serpentine belt was replaced my Meineke, it now gets only 30 mpg. What could they have done wrong?
  2. 09Prius2
    09Prius2 Member
    201
    88
    FL
    They may have knocked a connection loose while replacing the belt. Are there any lights on / check engine light?
  3. Joshace
    The check engine light has always been on as far as I can remember.
  4. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Yeah, check for something disconnected or not properly seated near the belt.
    Time to get the DTC codes read to help determine the underlying problem(s) with your car.
  5. 09Prius2
    09Prius2 Member
    201
    88
    FL
    If the check engine light has always been on than there would be no way of knowing if anything had changed due to the service, other than your mpg of course. As previously stated, the scan codes should provide you the relevant information you need.
    valde3 likes this.
